I have massive stuttering because of network buffering on 4K ISO with “this” experimental build (don’t know the others since 3D ist a must). The RPi4 and the Zidoo X9S, all devices connectet via wire to the same switch to avoid WLAN problems are working well (the RPi4 have other “micro-stuttering” issues)
I have the bad feeling that the Vero4k+ have some problems with the network performance.
This may also be a problem on playing 3D ISO.
How can i get the Vero4K+ to have a “clear enviroment”? If i put a Laptop on the same cable i’m writing and reading to the NAS with full speed (110 MB/s)
Not now.
I don’t know what the inbuild access is, i have defined a share via smb:.
Always via (Browse for new share -> add network location…) “Windows network SMB” don’t work for me.
The access to the server is on all my testing devices (RPi4 and Zidoo) always the same. If the Vero have special problems with SMB: i will try NFS: at home.
As long, as no other have the problem, i will dig out what’s wrong with my gear.
Ok, thanks means you have added it via Kodi and not Kernel (fstab/autofs) mounts. The kernel mounts are more performant but with a gigabit connection the Kodi solution should still work. So my recommentdation remains to first test the reverse iperf3 so that we can see from there.
Probably worth starting a new thread for this as I don’t think its related to 3D build and it will muddy this thread and won’t necessarily reach the people that can help you.
That’s great to hear. If you need any help path subbing your existing library feel free to ask. You can mark the topic as solved if everything is resolved.
If you wouldn’t mind could you state exactly what hardware your using for your file share.
