Buffering / Playing element on TV doesn't autohide (Confluence skin)
Hi, anyone know how to get the element pictured on screen to autohide itself ? It stays on screen permanently in a TV broadcast.
Only way I’ve found to get rid of it is to hit the back button on the remote then the OK/Select middle button on the remote to select the channel again, in that case it no longer appears.
Shouldn’t it autohide after 3 seconds or so ?
Try press Pause, then Play and see if it goes away. Noticed on Confluence an issue where GUI elements stayed on my screen when they shouldn’t. I will look in to it and address.
Thanks,will try.
This didn’t work (pause, play) - went back to OSMC skin in any case as the line has gone away it seems.
