recently I have buffering problems with internet streams , I looked for solutions and finally I completely reinstalled osmc on my rpi4 but the problems are not over, still buffering problems with internet streams. Nothing has changed about my home configuration very strange.
Live TV with pvr backend works perfectly.
Very annoying and I don’t know what to do
My internet connection is stable and constantly reaches almost 50Mbps
any solutions
am I the only one with this problem?
Without any logs, it’s hard to advise.
Ok I tried perform a log.
do you have any tips to show a log better here in a post ?
or is it enough ?
2022-04-02 15:06:49.058 T:10508 INFO : AddOnLog: pvr.vuplus: pvr.vuplus - Process Perform Updates!
2022-04-02 15:06:49.120 T:10508 ERROR : AddOnLog: pvr.vuplus: pvr.vuplus - LoadTimers Could not find element
2022-04-02 15:06:49.179 T:10508 ERROR : AddOnLog: pvr.vuplus: pvr.vuplus - LoadAutoTimers Could not find element!
2022-04-02 15:06:49.179 T:10508 ERROR : AddOnLog: pvr.vuplus: pvr.vuplus - TimerUpdatesAuto Unable to load auto timers, skipping auto timer update
2022-04-02 15:06:49.180 T:10511 INFO : AddOnLog: pvr.vuplus: pvr.vuplus - LoadRecordings Recordings Load Start: recordings
2022-04-02 15:06:49.298 T:10511 INFO : AddOnLog: pvr.vuplus: pvr.vuplus - GetRecordingsFromLocation Loaded 7 Recording Entries from folder ‘/media/hdd/movie/’
2022-04-02 15:06:49.298 T:10511 INFO : AddOnLog: pvr.vuplus: pvr.vuplus - LoadRecordings Recordings Load: recordings - 118 (ms)
2022-04-02 15:06:49.299 T:10511 INFO : AddOnLog: pvr.vuplus: pvr.vuplus - LoadRecordings Recordings Load Start: deleted items
2022-04-02 15:06:49.361 T:10511 INFO : AddOnLog: pvr.vuplus: pvr.vuplus - LoadRecordings Recordings Load: deleted items - 62 (ms)
2022-04-02 15:07:26.457 T:602 INFO : CActiveAESink::OpenSink - initialize sink
2022-04-02 15:07:26.457 T:602 INFO : CAESinkALSA::Initialize - Attempting to open device “@”
2022-04-02 15:07:26.460 T:602 INFO : CAESinkALSA - Unable to open device “surround51” for playback
2022-04-02 15:07:26.460 T:602 INFO : CAESinkALSA - Unable to open device “surround71” for playback
2022-04-02 15:07:26.461 T:602 INFO : CAESinkALSA::Initialize - Opened device “sysdefault”
2022-04-02 15:07:26.462 T:602 INFO : CAESinkALSA::InitializeHW - Unable to open the required number of channels
2022-04-02 15:07:26.462 T:602 INFO : CAESinkALSA::InitializeHW - Your hardware does not support AE_FMT_FLOAT, trying other formats
2022-04-02 15:07:26.462 T:602 INFO : CAESinkALSA::InitializeHW - Using data format AE_FMT_S24NE4
2022-04-02 15:07:28.990 T:12610 INFO : initializing python engine.
2022-04-02 15:07:29.095 T:12610 WARNING : CPythonInvoker(10): Script invoked without an addon. Adding all addon modules installed to python path as fallback. This behaviour will be removed in future version.
2022-04-02 15:07:42.371 T:12610 INFO : CPythonInvoker(10, /usr/share/kodi/addons/script.module.osmcsetting.logging//resources/lib/osmclogging/grablogs.py): script successfully run
2022-04-02 15:07:42.619 T:12610 INFO : Python interpreter stopped
2022-04-02 15:08:05.595 T:570 INFO : Loading skin file: DialogConfirm.xml, load type: KEEP_IN_MEMORY
2022-04-02 15:08:23.865 T:570 INFO : Loading skin file: MyVideoNav.xml, load type: KEEP_IN_MEMORY
2022-04-02 15:08:23.979 T:12698 ERROR : GetDirectory - Error getting -
2022-04-02 15:08:26.017 T:12710 INFO : initializing python engine.
2022-04-02 15:08:26.944 T:12710 INFO : CPythonInvoker(11, /home/osmc/.kodi/addons/plugin.video.vrt.nu/resources/lib/addon_entry.py): script successfully run
2022-04-02 15:08:31.303 T:12710 INFO : initializing python engine.
2022-04-02 15:08:31.384 T:12710 INFO : CPythonInvoker(11, /home/osmc/.kodi/addons/plugin.video.vrt.nu/resources/lib/addon_entry.py): script successfully run
2022-04-02 15:08:32.419 T:12710 INFO : initializing python engine.
2022-04-02 15:08:33.043 T:12710 WARNING : Invalid media type “”
2022-04-02 15:08:33.079 T:12710 INFO : Skipped 1 duplicate messages…
2022-04-02 15:08:33.079 T:12710 INFO : CPythonInvoker(11, /home/osmc/.kodi/addons/plugin.video.vrt.nu/resources/lib/addon_entry.py): script successfully run
2022-04-02 15:08:34.046 T:570 INFO : Loading skin file: DialogContextMenu.xml, load type: KEEP_IN_MEMORY
2022-04-02 15:08:36.358 T:12710 INFO : initializing python engine.
2022-04-02 15:08:37.071 T:12710 WARNING : [script.module.inputstreamhelper] Widevine update check was made on 2022-03-29 20:18
2022-04-02 15:08:37.138 T:570 INFO : VideoPlayer::OpenFile: plugin://plugin.video.vrt.nu/play/id/vid-e8635a30-168e-41cb-b31f-48c943968622/pbs-pub-af5bdbbb-ce3f-40b0-9135-9b7d17943f64
2022-04-02 15:08:37.140 T:12729 INFO : Creating InputStream
2022-04-02 15:08:37.146 T:12729 INFO : AddOnLog: inputstream.adaptive: SetVideoResolution (1360 x 768)
2022-04-02 15:08:37.192 T:12710 INFO : CPythonInvoker(11, /home/osmc/.kodi/addons/plugin.video.vrt.nu/resources/lib/addon_entry.py): script successfully run
2022-04-02 15:08:37.271 T:12729 INFO : AddOnLog: inputstream.adaptive: Successfully parsed manifest file. #Periods: 1, #Streams in first period: 4, Type: VOD, Download speed: 3022834.7327 Bytes/s
2022-04-02 15:08:39.847 T:12729 INFO : Creating Demuxer
2022-04-02 15:08:39.847 T:12729 INFO : Opening stream: 1001 source: 256
2022-04-02 15:08:39.869 T:12729 INFO : [WHITELIST] Searching the whitelist for: width: 960, height: 540, fps: 25.000, 3D: false
2022-04-02 15:08:39.870 T:12729 ERROR : ** T99 ** 960/540 vs. 1360/768 - 25.000000 vs. 60.000000, flags: 0x0
2022-04-02 15:08:39.870 T:12729 ERROR : ** T99 ** 960/540 vs. 1920/1080 - 25.000000 vs. 23.976025, flags: 0x0
2022-04-02 15:08:39.870 T:12729 ERROR : ** T99 ** 960/540 vs. 1920/1080 - 25.000000 vs. 24.000000, flags: 0x0
2022-04-02 15:08:39.870 T:12729 ERROR : ** T99 ** 960/540 vs. 1920/1080 - 25.000000 vs. 50.000000, flags: 0x0
2022-04-02 15:08:39.870 T:12729 ERROR : ** T99 ** 960/540 vs. 1920/1080 - 25.000000 vs. 59.940063, flags: 0x0
2022-04-02 15:08:39.870 T:12729 ERROR : ** T99 ** 960/540 vs. 1920/1080 - 25.000000 vs. 60.000000, flags: 0x0
2022-04-02 15:08:39.871 T:12729 INFO : Display resolution ADJUST : 1360x768 @ 60.000000 Hz (16) (weight: 0.000)
2022-04-02 15:08:39.873 T:12729 INFO : Creating video codec with codec id: 27
2022-04-02 15:08:39.873 T:12729 INFO : CDVDVideoCodecDRMPRIME::Open - using decoder V4L2 mem2mem H.264 decoder wrapper
2022-04-02 15:08:39.884 T:12729 INFO : Creating video thread
2022-04-02 15:08:39.885 T:12737 INFO : running thread: video_thread
2022-04-02 15:08:39.885 T:12729 INFO : Opening stream: 1002 source: 256
2022-04-02 15:08:39.910 T:12729 INFO : Finding audio codec for: 86018
2022-04-02 15:08:39.912 T:12729 INFO : CDVDAudioCodecFFmpeg::Open() Successful opened audio decoder aac
2022-04-02 15:08:39.912 T:12729 INFO : Creating audio thread
2022-04-02 15:08:39.912 T:12739 INFO : running thread: CVideoPlayerAudio::Process()
2022-04-02 15:08:39.912 T:12729 INFO : Opening stream: 1004 source: 256
2022-04-02 15:08:39.947 T:12729 INFO : AddOnLog: inputstream.adaptive: PosTime (272000)
2022-04-02 15:08:40.021 T:12729 INFO : AddOnLog: inputstream.adaptive: seekTime(272.0) for Stream:1 continues at 273.1 (PTS: 273050000)
2022-04-02 15:08:40.168 T:12729 INFO : AddOnLog: inputstream.adaptive: seekTime(273.1) for Stream:2 continues at 273.0 (PTS: 273045333)
2022-04-02 15:08:40.191 T:12729 INFO : AddOnLog: inputstream.adaptive: seekTime(273.1) for Stream:4 continues at 243.1 (PTS: 243050000)
2022-04-02 15:08:40.246 T:12739 INFO : CDVDAudioCodecFFmpeg::Open() Successful opened audio decoder aac
2022-04-02 15:08:40.246 T:12739 INFO : Creating audio stream (codec id: 86018, channels: 2, sample rate: 48000, no pass-through)
2022-04-02 15:08:40.266 T:602 INFO : CActiveAESink::OpenSink - initialize sink
2022-04-02 15:08:40.466 T:602 INFO : CAESinkALSA::Initialize - Attempting to open device “@”
2022-04-02 15:08:40.470 T:602 INFO : CAESinkALSA - Unable to open device “surround51” for playback
2022-04-02 15:08:40.470 T:602 INFO : CAESinkALSA - Unable to open device “surround71” for playback
2022-04-02 15:08:40.471 T:602 INFO : CAESinkALSA::Initialize - Opened device “sysdefault”
2022-04-02 15:08:40.471 T:602 INFO : CAESinkALSA::InitializeHW - Unable to open the required number of channels
2022-04-02 15:08:40.471 T:602 INFO : CAESinkALSA::InitializeHW - Your hardware does not support AE_FMT_FLOAT, trying other formats
2022-04-02 15:08:40.471 T:602 INFO : CAESinkALSA::InitializeHW - Using data format AE_FMT_S24NE4
2022-04-02 15:08:40.780 T:570 ERROR : Window Translator: Can’t find window True
2022-04-02 15:08:40.781 T:570 INFO : [WHITELIST] Searching the whitelist for: width: 960, height: 540, fps: 25.000, 3D: false
2022-04-02 15:08:40.781 T:570 ERROR : ** T99 ** 960/540 vs. 1360/768 - 25.000000 vs. 60.000000, flags: 0x0
2022-04-02 15:08:40.781 T:570 ERROR : ** T99 ** 960/540 vs. 1920/1080 - 25.000000 vs. 23.976025, flags: 0x0
2022-04-02 15:08:40.781 T:570 ERROR : ** T99 ** 960/540 vs. 1920/1080 - 25.000000 vs. 24.000000, flags: 0x0
2022-04-02 15:08:40.781 T:570 ERROR : ** T99 ** 960/540 vs. 1920/1080 - 25.000000 vs. 50.000000, flags: 0x0
2022-04-02 15:08:40.782 T:570 ERROR : ** T99 ** 960/540 vs. 1920/1080 - 25.000000 vs. 59.940063, flags: 0x0
2022-04-02 15:08:40.782 T:570 ERROR : ** T99 ** 960/540 vs. 1920/1080 - 25.000000 vs. 60.000000, flags: 0x0
2022-04-02 15:08:40.782 T:570 ERROR : ** T99 ** 960/540 vs. 1360/768 - 25.000000 vs. 60.000000, flags: 0x0
2022-04-02 15:08:40.782 T:570 INFO : Display resolution ADJUST : 1360x768 @ 60.000000 Hz (16) (weight: 0.000)
2022-04-02 15:08:43.814 T:12739 INFO : CVideoPlayerAudio::Process - stream stalled
2022-04-02 15:08:49.181 T:10508 INFO : AddOnLog: pvr.vuplus: pvr.vuplus - Process Perform Updates!
2022-04-02 15:08:49.243 T:10508 ERROR : AddOnLog: pvr.vuplus: pvr.vuplus - LoadTimers Could not find element
2022-04-02 15:08:49.302 T:10508 ERROR : AddOnLog: pvr.vuplus: pvr.vuplus - LoadAutoTimers Could not find element!
2022-04-02 15:08:49.302 T:10508 ERROR : AddOnLog: pvr.vuplus: pvr.vuplus - TimerUpdatesAuto Unable to load auto timers, skipping auto timer update
2022-04-02 15:08:49.303 T:10511 INFO : AddOnLog: pvr.vuplus: pvr.vuplus - LoadRecordings Recordings Load Start: recordings
2022-04-02 15:08:49.422 T:10511 INFO : AddOnLog: pvr.vuplus: pvr.vuplus - GetRecordingsFromLocation Loaded 7 Recording Entries from folder ‘/media/hdd/movie/’
2022-04-02 15:08:49.422 T:10511 INFO : AddOnLog: pvr.vuplus: pvr.vuplus - LoadRecordings Recordings Load: recordings - 119 (ms)
2022-04-02 15:08:49.424 T:10511 INFO : AddOnLog: pvr.vuplus: pvr.vuplus - LoadRecordings Recordings Load Start: deleted items
2022-04-02 15:08:49.486 T:10511 INFO : AddOnLog: pvr.vuplus: pvr.vuplus - LoadRecordings Recordings Load: deleted items - 62 (ms)
2022-04-02 15:09:13.718 T:570 INFO : Loading skin file: MyVideoNav.xml, load type: KEEP_IN_MEMORY
2022-04-02 15:09:13.831 T:12698 ERROR : GetDirectory - Error getting -
2022-04-02 15:09:13.895 T:12710 INFO : initializing python engine.
2022-04-02 15:09:19.377 T:12739 INFO : CVideoPlayerAudio::Process - stream stalled
2022-04-02 15:09:19.531 T:12710 WARNING : Invalid media type “”
2022-04-02 15:09:19.567 T:12710 INFO : Skipped 1 duplicate messages…
2022-04-02 15:09:19.567 T:12710 INFO : CPythonInvoker(11, /home/osmc/.kodi/addons/plugin.video.vrt.nu/resources/lib/addon_entry.py): script successfully run
2022-04-02 15:09:34.628 T:12710 INFO : initializing python engine.
2022-04-02 15:09:34.712 T:12710 INFO : CPythonInvoker(11, /home/osmc/.kodi/addons/plugin.video.vrt.nu/resources/lib/addon_entry.py): script successfully run
2022-04-02 15:09:35.534 T:12710 INFO : initializing python engine.
2022-04-02 15:09:35.628 T:12710 INFO : CPythonInvoker(11, /home/osmc/.kodi/addons/plugin.video.vrt.nu/resources/lib/addon_entry.py): script successfully run
2022-04-02 15:09:38.395 T:570 ERROR : Window Translator: Can’t find window True
2022-04-02 15:09:38.396 T:570 INFO : [WHITELIST] Searching the whitelist for: width: 960, height: 540, fps: 25.000, 3D: false
2022-04-02 15:09:38.396 T:570 ERROR : ** T99 ** 960/540 vs. 1360/768 - 25.000000 vs. 60.000000, flags: 0x0
2022-04-02 15:09:38.396 T:570 ERROR : ** T99 ** 960/540 vs. 1920/1080 - 25.000000 vs. 23.976025, flags: 0x0
2022-04-02 15:09:38.396 T:570 ERROR : ** T99 ** 960/540 vs. 1920/1080 - 25.000000 vs. 24.000000, flags: 0x0
2022-04-02 15:09:38.396 T:570 ERROR : ** T99 ** 960/540 vs. 1920/1080 - 25.000000 vs. 50.000000, flags: 0x0
2022-04-02 15:09:38.396 T:570 ERROR : ** T99 ** 960/540 vs. 1920/1080 - 25.000000 vs. 59.940063, flags: 0x0
2022-04-02 15:09:38.396 T:570 ERROR : ** T99 ** 960/540 vs. 1920/1080 - 25.000000 vs. 60.000000, flags: 0x0
2022-04-02 15:09:38.397 T:570 INFO : Display resolution ADJUST : 1360x768 @ 60.000000 Hz (16) (weight: 0.000)
2022-04-02 15:09:41.589 T:570 INFO : CVideoPlayer::CloseFile()
2022-04-02 15:09:41.589 T:570 INFO : VideoPlayer: waiting for threads to exit
2022-04-02 15:09:41.599 T:12729 INFO : CVideoPlayer::OnExit()
2022-04-02 15:09:41.599 T:12729 INFO : Closing stream player 1
2022-04-02 15:09:41.600 T:12729 INFO : Waiting for audio thread to exit
2022-04-02 15:09:41.629 T:12739 INFO : thread end: CVideoPlayerAudio::OnExit()
2022-04-02 15:09:41.629 T:12729 INFO : Closing audio device
2022-04-02 15:09:41.679 T:12729 INFO : Deleting audio codec
2022-04-02 15:09:41.679 T:602 INFO : CActiveAESink::OpenSink - initialize sink
2022-04-02 15:09:41.679 T:12729 INFO : Closing stream player 2
2022-04-02 15:09:41.679 T:12729 INFO : waiting for video thread to exit
2022-04-02 15:09:41.726 T:12737 WARNING : OutputPicture - timeout waiting for buffer
2022-04-02 15:09:41.726 T:12737 INFO : thread end: video_thread
2022-04-02 15:09:41.727 T:12729 INFO : deleting video codec
2022-04-02 15:09:41.732 T:12729 INFO : Closing stream player 3
2022-04-02 15:09:41.737 T:12683 INFO : Deleting settings information for files plugin://plugin.video.vrt.nu/play/id/vid-e8635a30-168e-41cb-b31f-48c943968622/pbs-pub-af5bdbbb-ce3f-40b0-9135-9b7d17943f64
2022-04-02 15:09:41.866 T:12729 INFO : ADDON: Dll Destroyed - InputStream Adaptive
2022-04-02 15:09:41.867 T:570 INFO : VideoPlayer: finished waiting
2022-04-02 15:09:41.867 T:570 INFO : CVideoPlayer::CloseFile()
2022-04-02 15:09:41.867 T:570 INFO : VideoPlayer: waiting for threads to exit
2022-04-02 15:09:41.879 T:602 INFO : CAESinkALSA::Initialize - Attempting to open device “@”
2022-04-02 15:09:41.882 T:602 INFO : CAESinkALSA - Unable to open device “surround51” for playback
2022-04-02 15:09:41.882 T:602 INFO : CAESinkALSA - Unable to open device “surround71” for playback
2022-04-02 15:09:41.883 T:602 INFO : CAESinkALSA::Initialize - Opened device “sysdefault”
2022-04-02 15:09:41.883 T:602 INFO : CAESinkALSA::InitializeHW - Unable to open the required number of channels
2022-04-02 15:09:41.883 T:602 INFO : CAESinkALSA::InitializeHW - Your hardware does not support AE_FMT_FLOAT, trying other formats
2022-04-02 15:09:41.883 T:602 INFO : CAESinkALSA::InitializeHW - Using data format AE_FMT_S24NE4
2022-04-02 15:09:41.891 T:570 ERROR : Window Translator: Can’t find window True
2022-04-02 15:09:45.934 T:12833 INFO : initializing python engine.
2022-04-02 15:09:46.185 T:12710 INFO : Python interpreter stopped
2022-04-02 15:09:46.415 T:12833 INFO : Skipped 6 duplicate messages…
2022-04-02 15:09:46.415 T:12833 INFO : CPythonInvoker(12, /usr/share/kodi/addons/service.osmc.settings/resources/lib/script.py): script successfully run
2022-04-02 15:09:46.556 T:12833 INFO : Python interpreter stopped
2022-04-02 15:09:47.153 T:570 INFO : Loading skin file: /usr/share/kodi/addons/service.osmc.settings/resources/skins/Default/1080i/settings_gui.xml, load type: LOAD_ON_GUI_INIT
2022-04-02 15:09:47.304 T:636 ERROR : EXCEPTION: Non-Existent Control 300
2022-04-02 15:09:50.890 T:12848 INFO : initializing python engine.
2022-04-02 15:09:51.009 T:12848 WARNING : CPythonInvoker(13): Script invoked without an addon. Adding all addon modules installed to python path as fallback. This behaviour will be removed in future version.
2022-04-02 15:10:49.305 T:10508 INFO : AddOnLog: pvr.vuplus: pvr.vuplus - Process Perform Updates!
2022-04-02 15:10:49.367 T:10508 ERROR : AddOnLog: pvr.vuplus: pvr.vuplus - LoadTimers Could not find element
2022-04-02 15:10:49.426 T:10508 ERROR : AddOnLog: pvr.vuplus: pvr.vuplus - LoadAutoTimers Could not find element!
2022-04-02 15:10:49.426 T:10508 ERROR : AddOnLog: pvr.vuplus: pvr.vuplus - TimerUpdatesAuto Unable to load auto timers, skipping auto timer update
2022-04-02 15:10:49.426 T:10511 INFO : AddOnLog: pvr.vuplus: pvr.vuplus - LoadRecordings Recordings Load Start: recordings
2022-04-02 15:10:49.545 T:10511 INFO : AddOnLog: pvr.vuplus: pvr.vuplus - GetRecordingsFromLocation Loaded 7 Recording Entries from folder ‘/media/hdd/movie/’
2022-04-02 15:10:49.545 T:10511 INFO : AddOnLog: pvr.vuplus: pvr.vuplus - LoadRecordings Recordings Load: recordings - 118 (ms)
2022-04-02 15:10:49.546 T:10511 INFO : AddOnLog: pvr.vuplus: pvr.vuplus - LoadRecordings Recordings Load Start: deleted items
2022-04-02 15:10:49.608 T:10511 INFO : AddOnLog: pvr.vuplus: pvr.vuplus - LoadRecordings Recordings Load: deleted items - 62 (ms)
2022-04-02 15:12:49.428 T:10508 INFO : AddOnLog: pvr.vuplus: pvr.vuplus - Process Perform Updates!
2022-04-02 15:12:49.490 T:10508 ERROR : AddOnLog: pvr.vuplus: pvr.vuplus - LoadTimers Could not find element
2022-04-02 15:12:49.548 T:10508 ERROR : AddOnLog: pvr.vuplus: pvr.vuplus - LoadAutoTimers Could not find element!
2022-04-02 15:12:49.548 T:10508 ERROR : AddOnLog: pvr.vuplus: pvr.vuplus - TimerUpdatesAuto Unable to load auto timers, skipping auto timer update
2022-04-02 15:12:49.549 T:10511 INFO : AddOnLog: pvr.vuplus: pvr.vuplus - LoadRecordings Recordings Load Start: recordings
2022-04-02 15:12:49.667 T:10511 INFO : AddOnLog: pvr.vuplus: pvr.vuplus - GetRecordingsFromLocation Loaded 7 Recording Entries from folder ‘/media/hdd/movie/’
2022-04-02 15:12:49.667 T:10511 INFO : AddOnLog: pvr.vuplus: pvr.vuplus - LoadRecordings Recordings Load: recordings - 118 (ms)
2022-04-02 15:12:49.668 T:10511 INFO : AddOnLog: pvr.vuplus: pvr.vuplus - LoadRecordings Recordings Load Start: deleted items
2022-04-02 15:12:49.730 T:10511 INFO : AddOnLog: pvr.vuplus: pvr.vuplus - LoadRecordings Recordings Load: deleted items - 62 (ms)
2022-04-02 15:14:05.240 T:602 INFO : CActiveAESink::OpenSink - initialize sink
2022-04-02 15:14:05.241 T:602 INFO : CAESinkALSA::Initialize - Attempting to open device “@”
2022-04-02 15:14:05.245 T:602 INFO : CAESinkALSA - Unable to open device “surround51” for playback
2022-04-02 15:14:05.245 T:602 INFO : CAESinkALSA - Unable to open device “surround71” for playback
2022-04-02 15:14:05.246 T:602 INFO : CAESinkALSA::Initialize - Opened device “sysdefault”
2022-04-02 15:14:05.246 T:602 INFO : CAESinkALSA::InitializeHW - Unable to open the required number of channels
2022-04-02 15:14:05.246 T:602 INFO : CAESinkALSA::InitializeHW - Your hardware does not support AE_FMT_FLOAT, trying other formats
2022-04-02 15:14:05.246 T:602 INFO : CAESinkALSA::InitializeHW - Using data format AE_FMT_S24NE4
2022-04-02 15:14:05.569 T:12848 INFO : CPythonInvoker(13, /usr/share/kodi/addons/script.module.osmcsetting.logging//resources/lib/osmclogging/grablogs.py): script successfully run
2022-04-02 15:14:05.818 T:12848 INFO : Python interpreter stopped
2022-04-02 15:14:11.778 T:12938 INFO : initializing python engine.
2022-04-02 15:14:11.933 T:12938 WARNING : CPythonInvoker(14): Script invoked without an addon. Adding all addon modules installed to python path as fallback. This behaviour will be removed in future version.
2022-04-02 15:14:16.216 T:12938 INFO : CPythonInvoker(14, /usr/share/kodi/addons/script.module.osmcsetting.logging//resources/lib/osmclogging/grablogs.py): script successfully run
2022-04-02 15:14:16.485 T:12938 INFO : Python interpreter stopped
2022-04-02 15:14:22.520 T:12997 INFO : initializing python engine.
2022-04-02 15:14:22.628 T:12997 WARNING : CPythonInvoker(15): Script invoked without an addon. Adding all addon modules installed to python path as fallback. This behaviour will be removed in future version.
2022-04-02 15:14:49.556 T:10508 INFO : AddOnLog: pvr.vuplus: pvr.vuplus - Process Perform Updates!
2022-04-02 15:14:49.621 T:10508 ERROR : AddOnLog: pvr.vuplus: pvr.vuplus - LoadTimers Could not find element
2022-04-02 15:14:49.681 T:10508 ERROR : AddOnLog: pvr.vuplus: pvr.vuplus - LoadAutoTimers Could not find element!
2022-04-02 15:14:49.681 T:10508 ERROR : AddOnLog: pvr.vuplus: pvr.vuplus - TimerUpdatesAuto Unable to load auto timers, skipping auto timer update
2022-04-02 15:14:49.681 T:10511 INFO : AddOnLog: pvr.vuplus: pvr.vuplus - LoadRecordings Recordings Load Start: recordings
2022-04-02 15:14:49.752 T:10511 INFO : AddOnLog: pvr.vuplus: pvr.vuplus - GetRecordingsFromLocation Loaded 7 Recording Entries from folder ‘/media/hdd/movie/’
2022-04-02 15:14:49.752 T:10511 INFO : AddOnLog: pvr.vuplus: pvr.vuplus - LoadRecordings Recordings Load: recordings - 71 (ms)
2022-04-02 15:14:49.754 T:10511 INFO : AddOnLog: pvr.vuplus: pvr.vuplus - LoadRecordings Recordings Load Start: deleted items
2022-04-02 15:14:49.817 T:10511 INFO : AddOnLog: pvr.vuplus: pvr.vuplus - LoadRecordings Recordings Load: deleted items - 62 (ms)
I think from 2022-04-02 15:08:37.138 I opened a stream…
reproduce the issue
upload the log set (all configs and logs!) either using the
I come back with the url
https://paste.osmc.tv/rinodateri
lot of buffering…
I think it is an add-on problem:
plugin.video.vrt.nu
especially in films, series and documentaries
netflix for example is no problem
reproduce:
add-on: plugin.video.vrt.nu
select a movie
and BAM buffering instant or after some seconds…
Raspberry Pi 4 Model B 8Gb + HIFIBERRY DIGI+ STANDARD
i’m not sure but the problems started with the last upgrade of Osmc
I hope you can check the log
Thanks in advance
erik
sorry everything work with the right widevine … thanks a lot.
in case of a problem I first have to come and look here
