OK,
problem reproduced. Put NFS in Synology behind firewall. Then try to alter the backup url by browsing. Notice: url was existing before browsing. When searching for the url is not successfull OSMC freezes. Kodi.old.log, I think it’s the last line were you can find the problem:
17:05:46 506286.281250 T:3025584688 NOTICE: special://profile/ is mapped to: special://masterprofile/
17:05:46 506286.281250 T:3025584688 NOTICE: -----------------------------------------------------------------------
17:05:46 506286.281250 T:3025584688 NOTICE: Starting Kodi (15.2-RC2). Platform: Linux ARM 32-bit
17:05:46 506286.281250 T:3025584688 NOTICE: Using Release Kodi x32 build (version for Raspberry Pi)
17:05:46 506286.281250 T:3025584688 NOTICE: Kodi compiled Sep 28 2015 by GCC 4.9.2 for Linux ARM 32-bit version 3.16.7 (200711)
17:05:46 506286.281250 T:3025584688 NOTICE: Running on Open Source Media Center 2015.09-2, kernel: Linux ARM 32-bit version 4.2.1-1-osmc
17:05:46 506286.281250 T:3025584688 NOTICE: FFmpeg statically linked, version: 2.6.4-kodi-2.6.4-Isengard
17:05:46 506286.281250 T:3025584688 NOTICE: Host CPU: ARMv6-compatible processor rev 7 (v6l), 1 core available
17:05:46 506286.281250 T:3025584688 NOTICE: ARM Features: Neon disabled
17:05:46 506286.281250 T:3025584688 NOTICE: special://xbmc/ is mapped to: /usr/share/kodi
17:05:46 506286.281250 T:3025584688 NOTICE: special://xbmcbin/ is mapped to: /usr/lib/kodi
17:05:46 506286.281250 T:3025584688 NOTICE: special://masterprofile/ is mapped to: /home/osmc/.kodi/userdata
17:05:46 506286.281250 T:3025584688 NOTICE: special://home/ is mapped to: /home/osmc/.kodi
17:05:46 506286.281250 T:3025584688 NOTICE: special://temp/ is mapped to: /home/osmc/.kodi/temp
17:05:46 506286.281250 T:3025584688 NOTICE: The executable running is: /usr/lib/kodi/kodi.bin
17:05:46 506286.281250 T:3025584688 NOTICE: Local hostname: osmc
17:05:46 506286.281250 T:3025584688 NOTICE: Log File is located: /home/osmc/.kodi/temp/kodi.log
17:05:46 506286.531250 T:3025584688 ERROR: DBus: Error org.freedesktop.DBus.Error.ServiceUnknown - The name org.freedesktop.UPower was not provided by any .service files
17:05:46 506286.656250 T:3025584688 NOTICE: load settings…
17:05:46 506286.906250 T:3025576992 NOTICE: Thread FDEventMonitor start, auto delete: false
17:05:46 506286.968750 T:3025584688 NOTICE: Found 1 Lists of Devices
17:05:46 506286.968750 T:3025584688 NOTICE: Enumerated PI devices:
17:05:46 506286.968750 T:3025584688 NOTICE: Device 1
17:05:46 506286.968750 T:3025584688 NOTICE: m_deviceName : HDMI
17:05:46 506286.968750 T:3025584688 NOTICE: m_displayName : HDMI
17:05:46 506286.968750 T:3025584688 NOTICE: m_displayNameExtra:
17:05:46 506286.968750 T:3025584688 NOTICE: m_deviceType : AE_DEVTYPE_HDMI
17:05:46 506286.968750 T:3025584688 NOTICE: m_channels : FL,FR
17:05:46 506286.968750 T:3025584688 NOTICE: m_sampleRates : 8000,11025,16000,22050,24000,32000,44100,48000,88200,96000,176400,192000
17:05:46 506286.968750 T:3025584688 NOTICE: m_dataFormats : AE_FMT_FLOAT,AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S32LE,AE_FMT_S16LE,AE_FMT_FLOATP,AE_FMT_S32NEP,AE_FMT_S16NEP,AE_FMT_AC3,AE_FMT_DTS,AE_FMT_EAC3
17:05:46 506286.968750 T:3025584688 NOTICE: Device 2
17:05:46 506286.968750 T:3025584688 NOTICE: m_deviceName : Analogue
17:05:46 506286.968750 T:3025584688 NOTICE: m_displayName : Analogue
17:05:46 506286.968750 T:3025584688 NOTICE: m_deviceType : AE_DEVTYPE_PCM
17:05:46 506286.968750 T:3025584688 NOTICE: m_sampleRates : 48000
17:05:46 506286.968750 T:3025584688 NOTICE: m_dataFormats : AE_FMT_FLOAT,AE_FMT_S32LE,AE_FMT_S16LE,AE_FMT_FLOATP,AE_FMT_S32NEP,AE_FMT_S16NEP
17:05:46 506286.968750 T:3025584688 NOTICE: Device 3
17:05:47 506286.968750 T:3025584688 NOTICE: m_deviceName : Both
17:05:47 506286.968750 T:3025584688 NOTICE: m_displayName : HDMI and Analogue
17:05:47 506286.968750 T:3025584688 NOTICE: m_displayNameExtra:
17:05:47 506286.968750 T:3025584688 NOTICE: m_deviceType : AE_DEVTYPE_PCM
17:05:47 506286.968750 T:3025584688 NOTICE: m_channels : FL,FR
17:05:47 506286.968750 T:3025584688 NOTICE: m_sampleRates : 48000
17:05:47 506286.968750 T:3025584688 NOTICE: m_dataFormats : AE_FMT_FLOAT,AE_FMT_S32LE,AE_FMT_S16LE,AE_FMT_FLOATP,AE_FMT_S32NEP,AE_FMT_S16NEP
17:05:47 506287.000000 T:3025584688 NOTICE: Loaded settings file from special://xbmc/system/advancedsettings.xml
17:05:47 506287.031250 T:3025584688 NOTICE: Contents of special://xbmc/system/advancedsettings.xml are…
<?xml version="1.0" encoding="UTF-8" ?>
4.0
540
720
false
0
30
17:05:47 506287.062500 T:3025584688 NOTICE: Loaded settings file from special://profile/advancedsettings.xml
17:05:47 506287.062500 T:3025584688 NOTICE: Contents of special://profile/advancedsettings.xml are…
1
0
30
17:05:47 506287.062500 T:3025584688 NOTICE: Default DVD Player: dvdplayer
17:05:47 506287.062500 T:3025584688 NOTICE: Default Video Player: dvdplayer
17:05:47 506287.062500 T:3025584688 NOTICE: Default Audio Player: paplayer
17:05:47 506287.062500 T:3025584688 NOTICE: Disabled debug logging due to GUI setting. Level 0.
17:05:47 506287.062500 T:3025584688 NOTICE: Log level changed to “LOG_LEVEL_NORMAL”
17:05:47 506287.062500 T:3025584688 NOTICE: CMediaSourceSettings: loading media sources from special://masterprofile/sources.xml
17:05:47 506287.062500 T:3025584688 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
17:05:47 506287.062500 T:3025584688 NOTICE: Loaded playercorefactory configuration
17:05:47 506287.062500 T:3025584688 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
17:05:47 506287.062500 T:3025584688 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
17:05:47 506287.468750 T:3015701536 NOTICE: Thread ActiveAE start, auto delete: false
17:05:47 506287.468750 T:3005215776 NOTICE: Thread AESink start, auto delete: false
17:05:47 506287.500000 T:2946495520 NOTICE: Thread CRBPWorker start, auto delete: false
17:05:47 506287.531250 T:3025584688 NOTICE: Running database version Addons19
17:05:48 506288.031250 T:3025584688 NOTICE: ADDONS: Using repository repository.superrepo.org.helix.repositories
17:05:48 506288.031250 T:3025584688 NOTICE: ADDONS: Using repository net.rieter.xot.repository
17:05:48 506288.031250 T:3025584688 NOTICE: ADDONS: Using repository repository.superrepo.org.helix.video
17:05:48 506288.031250 T:3025584688 NOTICE: ADDONS: Using repository repository.xbmc.org
17:05:48 506288.031250 T:3025584688 NOTICE: ADDONS: Using repository repository.superrepo.org.helix.album_information
17:05:48 506288.031250 T:3025584688 NOTICE: ADDONS: Using repository repository.superrepo.org.helix.regional.europe.netherlands
17:05:48 506288.031250 T:2936546336 NOTICE: Thread RemoteControl start, auto delete: false
17:05:48 506288.312500 T:3025584688 NOTICE: Raspberry PI firmware version: Sep 23 2015 12:21:14
Copyright (c) 2012 Broadcom
version c156d00b148c30a3ba28ec376c9c01e95a77d6d5 (clean) (release)
17:05:48 506288.312500 T:3025584688 NOTICE: ARM mem: 368MB GPU mem: 144MB MPG2:1 WVC1:0
17:05:48 506288.312500 T:3025584688 NOTICE: cacheMemBufferSize: 0MB
17:05:48 506288.312500 T:3025584688 NOTICE: Config:
arm_freq=850
config_hdmi_boost=2
core_freq=375
disable_auto_turbo=1
disable_commandline_tags=2
disable_overscan=1
emmc_pll_core=1
force_pwm_open=1
framebuffer_ignore_alpha=1
framebuffer_swap=1
hdmi_channel_map=8
hdmi_force_cec_address=65535
hdmi_force_hotplug=1
hdmi_ignore_cec_init=1
pause_burst_frames=1
program_serial_random=1
sdram_freq=400
sdtv_aspect=1
temp_limit=85
decode_MPG2=0x9f02cab2
device_tree=-
17:05:48 506288.343750 T:3025584688 NOTICE: InitWindowSystem: Using EGL Implementation: raspberrypi
17:05:48 506288.343750 T:3025584688 NOTICE: Found resolution 640 x 480 for display 0 with 640 x 480 @ 60.000000 Hz
17:05:48 506288.343750 T:3025584688 NOTICE: Found resolution 640 x 480 for display 0 with 640 x 480 @ 59.940063 Hz
17:05:48 506288.343750 T:3025584688 NOTICE: Found resolution 720 x 480 for display 0 with 720 x 480 @ 60.000000 Hz
17:05:48 506288.343750 T:3025584688 NOTICE: Found resolution 720 x 480 for display 0 with 720 x 480 @ 59.940063 Hz
17:05:48 506288.343750 T:3025584688 NOTICE: Found resolution 1280 x 720 for display 0 with 1280 x 720 @ 60.000000 Hz
17:05:48 506288.343750 T:3025584688 NOTICE: Found resolution 1280 x 720 for display 0 with 1280 x 720 @ 59.940063 Hz
17:05:48 506288.343750 T:3025584688 NOTICE: Found resolution 720 x 576 for display 0 with 720 x 576 @ 50.000000 Hz
17:05:48 506288.343750 T:3025584688 NOTICE: Found resolution 1280 x 720 for display 0 with 1280 x 720 @ 50.000000 Hz
17:05:48 506288.343750 T:3025584688 NOTICE: Found resolution 800 x 600 for display 0 with 800 x 600 @ 60.000000 Hz
17:05:48 506288.343750 T:3025584688 NOTICE: Found resolution 800 x 600 for display 0 with 800 x 600 @ 59.940063 Hz
17:05:48 506288.343750 T:3025584688 NOTICE: Found resolution 1024 x 768 for display 0 with 1024 x 768 @ 60.000000 Hz
17:05:48 506288.343750 T:3025584688 NOTICE: Found resolution 1024 x 768 for display 0 with 1024 x 768 @ 59.940063 Hz
17:05:48 506288.343750 T:3025584688 NOTICE: Found resolution 1360 x 768 for display 0 with 1360 x 768 @ 60.000000 Hz
17:05:48 506288.343750 T:3025584688 NOTICE: Found resolution 1360 x 768 for display 0 with 1360 x 768 @ 59.940063 Hz
17:05:48 506288.343750 T:3025584688 NOTICE: Found (1360x768@60.000000) at 28, setting to RES_DESKTOP at 16
17:05:48 506288.343750 T:3025584688 NOTICE: Checking resolution 16
17:05:48 506288.468750 T:3025584688 NOTICE: GL_VENDOR = Broadcom
17:05:48 506288.500000 T:3025584688 NOTICE: GL_RENDERER = VideoCore IV HW
17:05:48 506288.500000 T:3025584688 NOTICE: GL_VERSION = OpenGL ES 2.0
17:05:48 506288.500000 T:3025584688 NOTICE: GL_SHADING_LANGUAGE_VERSION = OpenGL ES GLSL ES 1.00
17:05:48 506288.500000 T:3025584688 NOTICE: GL_EXTENSIONS = GL_OES_compressed_ETC1_RGB8_texture GL_OES_compressed_paletted_texture GL_OES_texture_npot GL_OES_depth24 GL_OES_vertex_half_float GL_OES_EGL_image GL_OES_EGL_image_external GL_EXT_discard_framebuffer GL_OES_rgb8_rgba8 GL_OES_depth32 GL_OES_mapbuffer GL_EXT_texture_format_BGRA8888 GL_APPLE_rgb_422 GL_EXT_debug_marker
17:05:50 506290.000000 T:3025584688 NOTICE: Register - new cec device registered on cec->RPI: CEC Adapter (2708:1001)
17:05:50 506290.031250 T:2919769120 NOTICE: Thread CECAdapter start, auto delete: false
17:05:50 506290.125000 T:2894603296 NOTICE: Thread PeripBusUSBUdev start, auto delete: false
17:05:50 506290.312500 T:3025584688 NOTICE: Running database version Addons19
17:05:50 506290.312500 T:3025584688 NOTICE: Running database version ViewModes6
17:05:50 506290.312500 T:3025584688 NOTICE: Running database version Textures13
17:05:50 506290.343750 T:3025584688 NOTICE: Running database version MyMusic52
17:05:50 506290.375000 T:3025584688 NOTICE: Running database version MyVideos93
17:05:50 506290.375000 T:3025584688 NOTICE: Running database version TV29
17:05:50 506290.406250 T:3025584688 NOTICE: Running database version Epg10
17:05:50 506290.406250 T:3025584688 NOTICE: start dvd mediatype detection
17:05:50 506290.437500 T:2885215264 NOTICE: Thread DetectDVDMedia start, auto delete: false
17:05:52 506292.531250 T:3025584688 WARNING: JSONRPC: Could not parse type “PVR.Details.Channel”
17:05:52 506292.531250 T:3025584688 WARNING: JSONRPC: Could not parse type “PVR.Details.ChannelGroup.Extended”
17:05:52 506292.562500 T:3025584688 WARNING: JSONRPC: Could not parse type “GUI.Property.Value”
17:05:52 506292.593750 T:3025584688 WARNING: JSONRPC: Could not parse type “Setting.Details.SettingList”
17:05:52 506292.906250 T:2868864032 NOTICE: Thread LanguageInvoker start, auto delete: false
17:05:54 506294.218750 T:2860475424 NOTICE: Previous line repeats 2 times.
17:05:54 506294.218750 T:2860475424 NOTICE: -->Python Interpreter Initialized<–
17:05:55 506294.968750 T:2840028192 NOTICE: Previous line repeats 1 times.
17:05:55 506294.968750 T:2840028192 NOTICE: Thread JobWorker start, auto delete: true
17:05:55 506294.968750 T:2831639584 NOTICE: Thread LanguageInvoker start, auto delete: false
17:05:55 506295.031250 T:3025584688 NOTICE: Previous line repeats 4 times.
17:05:55 506295.031250 T:3025584688 NOTICE: initialize done
17:05:55 506295.031250 T:3025584688 NOTICE: Running the application…
17:05:55 506295.093750 T:3025584688 NOTICE: starting zeroconf publishing
17:05:55 506295.093750 T:3025584688 NOTICE: Webserver: Starting…
17:05:55 506295.093750 T:3025584688 NOTICE: WebServer: Started the webserver
17:05:55 506295.093750 T:3025584688 NOTICE: starting upnp client
17:05:55 506295.093750 T:2781307936 NOTICE: Thread JobWorker start, auto delete: true
17:05:55 506295.156250 T:3025584688 NOTICE: starting upnp server
17:05:55 506295.187500 T:3025584688 NOTICE: starting upnp controller
17:05:55 506295.187500 T:3025584688 NOTICE: starting upnp renderer
17:05:55 506295.250000 T:3025584688 NOTICE: ES: Starting event server
17:05:55 506295.281250 T:2660234272 NOTICE: Thread TCPServer start, auto delete: false
17:05:55 506295.281250 T:2668622880 NOTICE: Thread EventServer start, auto delete: false
17:05:55 506295.281250 T:2668622880 NOTICE: ES: Starting UDP Event server on 0.0.0.0:9777
17:05:55 506295.281250 T:2668622880 NOTICE: UDP: Listening on port 9777
17:05:55 506295.281250 T:2651845664 NOTICE: Thread JobWorker start, auto delete: true
17:05:55 506295.343750 T:2643457056 NOTICE: Thread CECAdapterUpdate start, auto delete: false
17:05:55 506295.468750 T:2625004576 NOTICE: Thread AirPlayServer start, auto delete: false
17:05:56 506296.437500 T:2697421856 NOTICE: Thread LanguageInvoker start, auto delete: false
17:06:04 506304.687500 T:2868864032 NOTICE: -->Python Interpreter Initialized<–
17:06:06 506306.375000 T:2599838752 NOTICE: Thread FileCache start, auto delete: false
17:06:06 506306.906250 T:2814862368 NOTICE: -->Python Interpreter Initialized<–
17:06:07 506307.343750 T:2599838752 NOTICE: Thread FileCache start, auto delete: false
17:06:07 506307.375000 T:2599838752 NOTICE: Thread LanguageInvoker start, auto delete: false
17:06:07 506307.875000 T:2651845664 ERROR: CCurlFile::FillBuffer - Failed: HTTP returned error 416
17:06:07 506307.875000 T:2651845664 NOTICE: CCurlFile::FillBuffer - Reconnect, (re)try 1
17:06:08 506308.093750 T:2714199072 NOTICE: Thread FileCache start, auto delete: false
17:06:08 506308.093750 T:2651845664 ERROR: Failed to fetch checksum for directory listing http://xml.superrepo.org/v5/.xml/helix/video/addons.xml for repository repository.superrepo.org.helix.video.
17:06:08 506308.437500 T:2714199072 NOTICE: Thread FileCache start, auto delete: false
17:06:17 506316.968750 T:2651845664 NOTICE: Previous line repeats 2 times.
17:06:17 506316.968750 T:2651845664 ERROR: CCurlFile::FillBuffer - Failed: HTTP returned error 416
17:06:17 506316.968750 T:2651845664 NOTICE: CCurlFile::FillBuffer - Reconnect, (re)try 1
17:06:17 506317.031250 T:2697421856 NOTICE: -->Python Interpreter Initialized<–
17:06:17 506317.218750 T:2714199072 NOTICE: Previous line repeats 1 times.
17:06:17 506317.218750 T:2714199072 NOTICE: Thread FileCache start, auto delete: false
17:06:17 506317.218750 T:2651845664 ERROR: Failed to fetch checksum for directory listing http://xml.superrepo.org/v5/.xml/helix/album_information/addons.xml for repository repository.superrepo.org.helix.album_information.
17:06:17 506317.406250 T:2651845664 ERROR: CCurlFile::FillBuffer - Failed: HTTP returned error 416
17:06:17 506317.406250 T:2651845664 NOTICE: CCurlFile::FillBuffer - Reconnect, (re)try 1
17:06:17 506317.656250 T:2714199072 NOTICE: Thread FileCache start, auto delete: false
17:06:17 506317.656250 T:2651845664 ERROR: Failed to fetch checksum for directory listing http://xml.superrepo.org/v5/.xml/helix/regional/europe/netherlands/addons.xml for repository repository.superrepo.org.helix.regional.europe.netherlands.
17:06:19 506319.531250 T:2806473760 NOTICE: -->Python Interpreter Initialized<–
17:06:24 506323.968750 T:2814862368 NOTICE: Previous line repeats 2 times.
17:06:24 506323.968750 T:2814862368 NOTICE: StorageServer Module loaded RUN
17:06:24 506323.968750 T:2814862368 NOTICE: StorageClient-2.5.4 Starting server
17:06:28 506328.812500 T:2599838752 NOTICE: -->Python Interpreter Initialized<–
17:06:34 506334.875000 T:2806473760 NOTICE: 1Channel: Service: Installed Version: 2.5.64
17:06:36 506336.750000 T:2806473760 NOTICE: 1Channel: Loading sqlite3 as DB engine
17:06:37 506337.500000 T:2806473760 NOTICE: 1Channel: Service: Resetting…
17:06:37 506337.500000 T:2806473760 NOTICE: 1Channel: Service: starting…
17:06:40 506340.750000 T:2840028192 NOTICE: AxelProxy Downloader Starting - 127.0.0.1:45550
17:06:40 506340.750000 T:2840028192 NOTICE: Press CTL break to stop…
17:06:45 506345.750000 T:2697421856 NOTICE: Thread LanguageInvoker start, auto delete: false
17:06:46 506346.406250 T:2697421856 NOTICE: -->Python Interpreter Initialized<–
17:06:52 506352.875000 T:2553279520 NOTICE: Thread JobWorker start, auto delete: true
17:06:53 506353.906250 T:2697421856 NOTICE: Previous line repeats 1 times.
17:06:53 506353.906250 T:2697421856 NOTICE: CommonFunctions-2.5.1
17:06:54 506354.062500 T:2697421856 ERROR: GetDirectory - Error getting /home/osmc/.kodi/userdata/addon_data/plugin.video.genesis/TVShows/
17:06:56 506356.406250 T:2851824672 ERROR: EXCEPTION: Non-Existent Control 300
17:07:08 506368.406250 T:2668622880 NOTICE: ES: Client from 192.168.178.22 timed out
