Bug: ignore versions lost on reboot (Kodi v21 Vero V)
Just updated, glad to have versions - now I can match my Letterboxd list count to the count in my Kodi and keep them in sync better.
However I have one issue: the Settings / Media “Ignore different video versions on scan” setting is on by default and disabling it only has effect until the next reboot. After reboot the option turns back on.
Try setting it off then restart Kodi Power->Exit. After that the setting should stick through a reboot.
Thanks. It somehow fixed itself. Got stored without doing the exit step.
