As the title says, I don’t know if this is a big or just a strange glitch or what but figured I’d mention it in case someone else notices.
Device: Raspberry Pi 2
OSMC v: 2017.10-1
Kernel: Linux 4.9.29-10-osmc
I had turned the RPi (& other devices) off since before Xmas as we were away for a few days. On returning today I switched everything back on again.
On getting ready to watch a show I noticed the screen resolution was all out of whack, this has happened before after an update so I figured there might have been one applied during the start up today. I just adjusted the res in the settings and watched some shows.
When I was getting ready to turn the TV off (RPi stays on) I noticed the time read 1940h when it was about 0130h. Thinking it might have been an update issue again I went into settings to adjust it. I tried changing the timezone and returning to the UK a few times but the incorrect time kept returning, I also noticed the date was reading 23rd Dec (today is 31st).
I then rebooted OSMC and the correct date and time are now showing.
Just an FYI for the dev, not sure if it’s an issue at all but I’ll leave that with you.
