Hello there,
since June update i have small, but annoying bug with my bluetooth airmouse.
Every time when mouse connects and disconnects (because of power saving) from Vero - sound (using optical port and pass through) is interrupted twice.
Always exactly the same behaviour.
Is there something i can do about it please?
Thanks a lot for your time and help.
Which version did you previously upgrade from? Can you post some logs?
I upgraded as usual from previous (march) build using built in updater.
Never had this problem before with same configuration (updated regularly).
Never did any special tampering with system.
Thanks for confirming. I can’t think of any changes in this update which could cause this.
Can you please upload some debug logs after the problem occurs?
