Build PVR add-on from git source
Thank you for the fast replay!
Actually I’m trying to build against Kodi 18.Could you point me to the appropiate patch? For some reason I can’t find the right page.
robotrumble
Look under GitHub, Krypton branch.
If you’re building Kodi v18, then you might want to talk to @gmc as the current autoconf system has been deprecated, and some work (if you have done it already) on fully transitioning to CMake would be appreciated.
Try this binary:
on OSMC Krypton.
Regards, Radek.
Just a heads up that OSMC for Raspberry Pi 2/3 is not based on Raspbian. So you would want to built using a Debian armv7 userland for best performance (although it will not likely matter in this scenario)
Sorry my mistake with Raspbian. This add-on was build on osmc directly and working fine on my raspberry pi 2 with osmc.
Regards
