I’m trying to get this PVR addon working too
On line 10, i’m getting this error.
CMake Error: The source directory “/tmp/src/pvr.iptvsimple/build/-” does not exist.
Specify --help for usage, or press the help button on the CMake GUI.
I’ve copied CMakelists.txt to tmp/src/pvr.iptvsimple/build but i’m getting this error.
CMake Error: Error in cmake code at
/tmp/src/pvr.iptvsimple/build/CMakeLists.txt:5:
Parse error. Expected a command name, got unquoted argument with text “<!DOCTYPE”.
– Configuring incomplete, errors occurred!
CMake Error: CMake was unable to find a build program corresponding to “Unix Makefiles”. CMAKE_MAKE_PROGRAM is not set. You probably need to select a different build tool.
CMake Error: Error required internal CMake variable not set, cmake may be not be built correctly.
Missing variable is:
CMAKE_C_COMPILER_ENV_VAR
CMAKE_C_COMPILER
CMake Error: Could not find cmake module file: /tmp/src/pvr.iptvsimple/build/CMakeFiles/3.0.2/CMakeCCompiler.cmake
CMAKE_CXX_COMPILER_ENV_VAR
CMAKE_CXX_COMPILER
CMake Error: Could not find cmake module file: /tmp/src/pvr.iptvsimple/build/CMakeFiles/3.0.2/CMakeCXXCompiler.cmake
CMake Error at CMakeLists.txt:1 (project):
No CMAKE_C_COMPILER could be found.
Tell CMake where to find the compiler by setting the CMake cache entry
CMAKE_C_COMPILER to the full path to the compiler, or to the compiler name
if it is in the PATH.
No CMAKE_CXX_COMPILER could be found.
CMAKE_CXX_COMPILER to the full path to the compiler, or to the compiler
name if it is in the PATH.
CMake Error: CMAKE_C_COMPILER not set, after EnableLanguage
CMake Error: CMAKE_CXX_COMPILER not set, after EnableLanguage
Hi all,
sorry for reopening an old thread, but I didn’t want to start a new one.
Everytime I try to run the cmake comand it stops with an error.
As far as I can tell the most relevant part of the error message is that one:
[quote]-- Build files have been written to: /tmp/src/pvr.zattoo/build/build/bootstrap
Scanning dependencies of target binary-addons
[ 12%] Creating directories for ‘binary-addons’
[ 25%] Performing download step (git clone) for ‘binary-addons’
Klone nach ‘binary-addons’…
Bereits auf ‘master’
Ihr Branch ist auf dem selben Stand wie ‘origin/master’.
[ 37%] No patch step for ‘binary-addons’
[ 50%] Performing update step for ‘binary-addons’
Current branch master is up to date.
[ 62%] No configure step for ‘binary-addons’
[ 75%] No build step for ‘binary-addons’
[ 87%] Performing install step for ‘binary-addons’
– Bootstrapping following addons: pvr.zattoo
[100%] Completed ‘binary-addons’
[100%] Built target binary-addons
CMake Error at CMakeLists.txt:220 (message):
No addons available to be built[/quote]
[details=Complete CMake log]-- The C compiler identification is GNU 4.9.2
– The CXX compiler identification is GNU 4.9.2
– Check for working C compiler: /usr/bin/cc
– Check for working C compiler: /usr/bin/cc – works
– Detecting C compiler ABI info
– Detecting C compiler ABI info - done
– Detecting C compile features
– Detecting C compile features - done
– Check for working CXX compiler: /usr/bin/c++
– Check for working CXX compiler: /usr/bin/c++ – works
– Detecting CXX compiler ABI info
– Detecting CXX compiler ABI info - done
– Detecting CXX compile features
– Detecting CXX compile features - done
– Addon source tarball caching is enabled
– ZIP packaging enabled (destination: /tmp/src/pvr.zattoo/build/build/zips)
– Building following addons: pvr.zattoo
– Overriding addon source directory prefix: /tmp/src
– ---- Preparing general dependencies ----
– Processing /tmp/src/xbmc/cmake/addons/depends/common/kodi-platform/kodi-platform.txt
– kodi-platform url: GitHub - xbmc/kodi-platform: Kodi platform support library
– kodi-platform depends: tinyxml;p8-platform
– Processing /tmp/src/xbmc/cmake/addons/depends/common/p8-platform/p8-platform.txt
– p8-platform url: https://github.com/Pulse-Eight/platform.git
– Processing /tmp/src/xbmc/cmake/addons/depends/common/tinyxml/tinyxml.txt
– tinyxml url: http://mirrors.kodi.tv/build-deps/sources/tinyxml-2.6.2_2.tar.gz
– No platform specific file /tmp/src/xbmc/cmake/addons/depends/linux/CMakeLists.txt found
– Bootstrapping all default repositories as no addons were found…
– The C compiler identification is GNU 4.9.2
– Bootstrapping all repositories
– Bootstrapping addons from binary-addons (https://github.com/xbmc/repo-binary-addons.git master)…
– Configuring done
– Generating done
– Build files have been written to: /tmp/src/pvr.zattoo/build/build/bootstrap
