I was going to buy the MPEG-2 codec for run DVD on OSMC but I have two questions.
Will it work with Raspbian too? The serial of the codec is not just for OSMC, right?
What’s VC-1 codec?
Thanks!
What’s VC-1 codec?
Thanks!
Codec is for the device, not the OS.
Ok, and what’s VC-1?
Thanks!
Then it’s for Blu-ray discs and Silverlight plugin for reproduce videos in some webs… I see… I’ll buy this too.
Thanks ActionA!
PS: If you can edit your second post and paste VC-1 info it’ll be great because I put post #2 as the answer
Be aware, silverlight is not (easily) compatible or used on Linux systems such as OSMC.
I’ll use it for wmv videos too. If I need silverlight support or something, I’ll search about it. (And I already place the order so I can’t delete it)
