Hello… I have a project with a car wirelessly controlled from the raspberry pi , and have to integrate a bluetooth module with the C language and controlled from the cell phone . And also see if this language is similar to arduino´s C , the truth is I have no idea what to do . Thank you in advance for your help.
Thank for your help.
Unless you are trying to do something with Kodi, you are in the wrong place. Check with the Raspberry Pi [forums] (Raspberry Pi Forums - Index page) for help. But to answer your question, The Gnu C compiler works on any Linux based system. I have no idea what Arduino C is.
c is a programming language and does not change only versions are being handled
