I followed the instructions here and here . But when I try to launch I get this error message:
…original files to /home/osmc/.local/share/SteamLink/.old
cannot stat ‘/home/osmc/.local/share/SteamLink/*’ : No Such file or directory
need to run on a Rspberry Pi 3 or newer - aborting.
Well I guess situation hasn’t changed and currently not available on Vero
Currently not available on Vero since its a diffrent SoC but who knows what the future holds first off its Rpi and getting it stable there so have some patience and see what the future holds
Oh well. How do I undo the install?
Well I assume you installed via dpkg -i so to remove/prune the command is dpkg -P to find the exact package name for uinstall use dpkg -l | grep steam
Toast
7 January 2020 18:20
5
sudo apt remove steamlink -y
99% sure, at work so i cant doublecheck.
That seemed to work. Thank you.
Its 2022 any progress with Steam Link on Vero 4k+ , OSMC ??
My understanding is that Steam Link was closed source and built against RPI OMX libs (which are now not even used on modern Pi stack), and that there was not change from Valve.
I may be wrong, but don’t know enough about it to advise.
Toast
27 April 2022 17:12
9
true rpi only but using new packages
I have a RPi3+ with OSMC (Kodi 18, Leia) installed on it. I've been using swetoast/steamlink-launcher (0.0.6a) on it to launch Steam Link directly from Kodi. Suddenly. today, when starting steamlink, it required an additional package: ~$ steamlink...
sudo apt install libgles2 libegl1 libgl1-mesa-dri
advice the op to seek support from valve rather then osmc in the future for better support regarding steamlink
