If it can be extended - can you give me the size and type of connection to purchase?
Thanks,
Thanks,
There is an extender in the box.
What kind of range are you going for?
I mean to electrically extend the sensor with a male to female extension cable.
Yes. You can use a 3.5mm cable.
Thanks, you da man.
