I need to kill Kodi in order have my moonlight session beeing visible.
I followed this guide:
And tried to stop and disable Kodi.
Unfortunately Kodi keeps coming back after a few seconds.
Also rebooting didn’t help.
All of the following commands fail to keep Kodi closed permanently:
sudo systemctl disable mediacenter
pkill kodi
Kodi closes but it starts again after maybe 15 seconds or so and then is shown on top of my moonlight session window making it impossible to see my moonlight screen session.
How can i close Kodi either until reboot or permanetly, or alternatively put it inot background of my moonlight session?
I would prefer a solution via script that closes Kodi and starts my moonlight command.
No i just stream the screen. I control the pc or osmc via iphone only. Or sometimes play games with an xbox one controller that is paired to the windows pc.
So only the pc has keyboard/mose. The raspberry has just a wifi dongle nothing else.
