I have a small problem when starting OSMC. If my hard drive is not connected to my RPI, kodi does not start “A start job is running for dev-disk-by”
My fstab file
/dev/mmcblk0p1 /boot vfat defaults,noatime,noauto,x-systemd.automount 0
0 UUID=5EFUFAE7FELAB0FF /mnt/data ntfs defaults,relatime 0 0,noauto
# rootfs is not mounted in fstab as we do it via initramfs. Uncomment for remount (slower boot)#/dev/mmcblk0p2 / ext4 defaults,noatime 0 0
Why do you mount it via fstab and don’t use the fabulous automount of OSMC which would avoid your problem?
Just ensure your drive has a proper label then it is automounted under /media/
fzinken: I always use this command, has it changed now ?
It is mounted on /mnt/
dillthedog: I have always entered this line otherwise my hard drive does not appear. It is this command that allowed me to start OSMC without my hardrive connected.
Again, has it changed now ?
Well nothing has changed, but you don’t need to do what you do! Just remove the line from fstab an you will find your harddisk autmounted under /media. This is a much better option especially for disk that is not always connected
If you want to achieve something similar with fstab (but WHY?) then use x-systemd.automount option
