Can OSMC be installed in a normal laptop?
Currently i have kodi installed on an old laptop for watching movies and TV Shows. Once i saw OSMC I immediately wanted to install it but i didnt see an option for installing it in something other than vero, pi, or apple tv.
So, is it possible to install OSMC in a normal laptop or a PC?
What part did you see? The Skin?
Yes you can install the skin on other Kodi installation
to install OSMC as an operating system on a X86 machine that is currently not fully supported and will most likely once it is there only support x64
