I’m trying to make a home entertainment system, but I can’t figure out if OSMC can run on RPI 3 a+.
Thanks,
Sowkai.
Thanks,
Sowkai.
The 512mb RAM allotted is probably going to hinder performance. There’s nothing wrong with trying it though. I’d just try the rpi3 OSMC installation software.
I’d also add that it has no ethernet adapter and only one USB port.
You’d do a lot better with a Pi 3B+.
Yes – it can run.
Depends on the size of your library. I have Raspberry Pi 3+ and it crash a lot because with the size of my library. …And before everyone jumps on me I have several some with addons and some with nothing.
I don’t really care about ethernet.
