Needed to reinstall from scratch. Got to the pairing screen, it says to hold home (top left) and OK to pair, but it doesn’t pair. On the off chance the battery died exactly at the time I wanted to reinstall, got new battery, tested with multimeter, and still won’t pair.
I have no USB devices attached to the Vero V. I can put the remote right over it and hold home and ok, doesn’t pair.
How can I get it paired? Remote was working before reinstall.
It appears the battery is finicky as far as the fit. Tried 3-4 times and finally it works again. Don’t recall the voltage, was new from pack, was like .2 over spec.
