Looking to reduce the file transfer time from my PC to the storage attached to the Vero, can sabnzbd be installed and run on the Vero?
I saw some threads from 2015 and '16 that looked like it was being looked into but didn’t see anything else on it or guides.
If there’s a guide or a link, I’d appreciate a nudge in the right direction.
Thanks!
I know NZBGet has support for some ARM devices not sure if vero is one of them
It says Pi2 but should also work fine for Vero4k
Yes — it can be installed
Thanks guys. If it’s as per the instructions that ActionA listed…I may need more coffee as that looks a bit more involved than installing from the app store kinda thing
If it works, I’ll certainly look into that and follow the steps and give it a go.
I wonder how long it takes for the 4k to unpack and if needed repair a UHD remux. I’m guessing hours?
No idea I’m afraid. But if you have some info, let us know.
Remuxing is a fast process.
I was talking about unpacking the discussions to media
It will depend on number of archives.
I don’t know how bad it will be – maybe some others can advise.
