I used to be able to connect to my wifi just fine but somehow it stopped working. Forgetting the networking and connecting to it again doesn’t work either. Ethernet works.
I would try this, you will need to access the command line:
https://osmc.tv/wiki/general/accessing-the-command-line/
issue the following command:
sudo rm-rf /var/lib/connman/wifi*
and reboot or sudo reboot 0
Thanks Tom.
That made it working again, thank you!
