Can`t connect to raspberry pi via ssh or samba
Hello,
i can`t connect to my raspberry pi 2 via ssh oder samba, allm services are installed and applyied.
it always says invalied password, acces denied.
i have also tried deinstall, ssh und samba service and install it new, but nothing changed.
can you help me?
greetz
So you used osmc as the username and password ?
Did you change the passwords at any point ?
yes, i used osmc as username and pw.
i have nothing changed. i read in the forum here, when i install the services new, the default username and pw are actual.
Well as @dbmandrake asked are you using the right user/password combination? As definetly you get rejected because of wrong password
> Jan 07 22:02:22 osmc sshd[674]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=192.168.2.105  user=osmc
> Jan 07 22:02:24 osmc sshd[674]: Failed password for osmc from 192.168.2.105 port 52803 ssh2
But actually I really hope that you have changed your password as you seem to have port forwarding from internet activate
> Jan 08 00:40:33 osmc sshd[1587]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=218.87.109.253 user=root
> Jan 08 00:40:34 osmc sshd[1587]: Failed password for root from 218.87.109.253 port 22473 ssh2
> Jan 08 00:40:36 osmc sshd[1587]: Failed password for root from 218.87.109.253 port 22473 ssh2
> Jan 08 00:40:40 osmc sshd[1587]: Failed password for root from 218.87.109.253 port 22473 ssh2
> Jan 08 00:40:43 osmc sshd[1587]: Failed password for root from 218.87.109.253 port 22473 ssh2
> Jan 08 00:40:45 osmc sshd[1587]: Failed password for root from 218.87.109.253 port 22473 ssh2
> Jan 08 00:40:48 osmc sshd[1587]: Failed password for root from 218.87.109.253 port 22473 ssh2
i think i only have port fowarding for port 9091 and one for transmission daemon.
how can i change my password without access over ssh.
i installed osmc again, now it works
And please stop that internet portforwarding, before you know you are in the news arrested for spreading stuff you don’t even know about
Do a search for (open)VPN and than you can access outside from your mobile with a VPN connection everything you have at home like you are on your home network.
My situation, using linux router/server (ClearOs) with VPN, on my mobile openvpn client and I can access everything at home with their LAN ip’s
