Hello,
I just installed my Vero 4K+. It is connected to a Marantz 8805 pre/pro to a Sony VPL-VW715ES projector. I backed up my Jurassic World 3D Blu-Ray using DVDFab12 as a 3D ISO file. The physical DVD plays 3D fine in my Sony Blu Ray player but when I select it on the Vero 4K+ I just get a blank screen. It does ask me if I want to play the 3D format of the default movie, and when I do, my screen goes blank and I don’t get any audio. I have to keep hitting the back button on the remote to get out of the movie. If my projector does not see a compatible 3D player, it won’t let me access any of the 3D menus on the projector either.
Please help. I am desperately trying to get 3D playback in my theater.
I am running OSMC August 2021.08-01
Here is my log file https://paste.osmc.tv/exuqayozox
Start with following the below advice and see if that makes a difference.
We recommend people with 4K TV’s set their user interface (UI) to 1080p. Kodi’s UI is not optimized for 4K yet and this can put unnecessary demands on your device and can lead to a suboptimal picture quality, as well as potentially cause other issues.
The settings we recommend are as follows…
Settings>System>Display>Resolution> 1920x1080p
Settings>System>Display>Whitelist> (empty) *
Some televisions may also need, or benefit from, the following being set…
System>Display>Force 4:2:2 colour subsampling> (enable)
With the above settings your UI will be output in Full HD and your 4K content will be output in 4K. *Information regarding the whitelist can be found here. If you have any doubt, feel free to upload some logs so we can verify that your settings are indeed correct.
If I could virtually hug you, I would. That worked. Awesome!
