Hi @sam_nazarko,
Partial success.
When using the screensaver add-on from your link, after a period of inactivity the vero’s led turns red, then the monitor powers off the backlight.
After maybe 20 seconds the backlight returns, although the image is a black screen. The monitor never enters standby mode (no message, no change in monitor’s led status colour).
In contrast, using ‘Suspend’ from the power menu, the Vero’s led turns red, the monitor powers off the display/backlight for a few seconds, then it powers back up to show an in-built ‘no signal’ message. A few seconds later the monitor powers off again, with its own led changing colour to confirm this.
I enabled debug logging and notification logs, then rebooted.
I waited for the screensaver to activate, then after a minute or so I used the remote’s ‘ok’ button, navigated to the power menu, and selected ‘suspend’.
In the log, after the 2 minute timeout I set for the screensaver, I can see the debug messages as set in the screensaver’s gui.py.
I can also see the log messages for the activation of the Suspend mode (whereby the display correctly powers down).
Happy to upload the log file from /home/osmc/.kodi/temp/kodi.log if you provide a location
Excerpt from log file:
20:13:05.217 T:4079919872 DEBUG: CAnnouncementManager - Announcement: OnScreensaverActivated from xbmc
20:13:05.217 T:4079919872 DEBUG: GOT ANNOUNCEMENT, type: 4, from xbmc, message OnScreensaverActivated
20:13:05.545 T:3853554432 DEBUG: CPythonInvoker(5, /home/osmc/.kodi/addons/script.vero4kstandby/default.py): start processing
20:13:05.775 T:3853554432 DEBUG: CPythonInvoker(5, /home/osmc/.kodi/addons/script.vero4kstandby/default.py): instantiating addon using automatically obtained id of "script.vero4kstandby" dependent on version 2.19.0 of the xbmc.python api
20:13:05.915 T:3853554432 DEBUG: TMDS to 0
20:13:05.916 T:3853554432 DEBUG: Toggling HDMI TMDS clock
20:13:05.916 T:3853554432 DEBUG: Toggling LED
20:13:05.916 T:3853554432 DEBUG: ConnMan is to stop
20:13:05.916 T:3853554432 DEBUG: Toggling network connectivity
20:13:07.367 T:3836777216 DEBUG: VPN Mgr : Encountered a new window ID 12900
20:13:07.373 T:3836777216 DEBUG: VPN Mgr : Previous window ID was 10000
20:13:08.127 T:3853554432 DEBUG: Using powersave governor
20:13:08.128 T:3853554432 DEBUG: Toggling CPU governor
20:13:42.057 T:3881415424 DEBUG: script.module.osmcsetting.updates : - blurp 485 - /home/osmc/.kodi/addons/script.vero4kstandby/resources/skins/default/720p/dummy.xml
20:13:43.074 T:4079923792 DEBUG: LIRC: Update - NEW at 160899:160 0 KEY_OK linux-input-layer (KEY_OK)
