Hello. Lately I’m starting to block the vero. It stays frozen and does not respond to any action. I have not changed or touched anything for months. Simply use to view content by network as the first day.
The only way to revive it is to remove the cable from the electrical network and reconnect.
Another question I have is. If I put a custom Wizard, I guess the My OSMC app will disappear. How could I recover it in the case of trying the Wizard?
The MyOSMC app will always be found under program addons. You locking issue will require logs to determine any cause.
reboot the OSMC device
reproduce the issue
upload the log set either using the Log Uploader method within the My OSMC menu in the GUI or the ssh method invoking command grab-logs -A
