Is there a wiki that would show me how to pull a log?
I’ve gone into event log in the system menu, when I hit enter on the open box icon nothing happens
21:31:56.817 T:4082369104 NOTICE: special://profile/ is mapped to: special://masterprofile/
21:31:56.817 T:4082369104 NOTICE: -----------------------------------------------------------------------
21:31:56.817 T:4082369104 NOTICE: Starting Kodi (17.6). Platform: Linux ARM (Thumb) 32-bit
21:31:56.817 T:4082369104 NOTICE: Using Release Kodi x32 build (version for Vero)
21:31:56.817 T:4082369104 NOTICE: Kodi compiled Oct 31 2018 by GCC 6.3.0 for Linux ARM (Thumb) 32-bit version 4.9.30 (264478)
21:31:56.818 T:4082369104 NOTICE: Running on Open Source Media Center 2018.10-1, kernel: Linux ARM 32-bit version 3.14.29-126-osmc
21:31:56.818 T:4082369104 NOTICE: FFmpeg version/source: ffmpeg-3.1-kodi
21:31:56.818 T:4082369104 NOTICE: Host CPU: AArch64 Processor rev 4 (aarch64), 4 cores available
21:31:56.818 T:4082369104 NOTICE: ARM Features: Neon disabled
21:31:56.818 T:4082369104 NOTICE: special://xbmc/ is mapped to: /usr/share/kodi
21:31:56.818 T:4082369104 NOTICE: special://xbmcbin/ is mapped to: /usr/lib/kodi
21:31:56.818 T:4082369104 NOTICE: special://xbmcbinaddons/ is mapped to: /usr/lib/kodi/addons
21:31:56.818 T:4082369104 NOTICE: special://masterprofile/ is mapped to: /home/osmc/.kodi/userdata
21:31:56.818 T:4082369104 NOTICE: special://envhome/ is mapped to: /home/osmc
21:31:56.818 T:4082369104 NOTICE: special://home/ is mapped to: /home/osmc/.kodi
21:31:56.818 T:4082369104 NOTICE: special://temp/ is mapped to: /home/osmc/.kodi/temp
21:31:56.818 T:4082369104 NOTICE: special://logpath/ is mapped to: /home/osmc/.kodi/temp
21:31:56.818 T:4082369104 NOTICE: The executable running is: /usr/lib/kodi/kodi.bin
21:31:56.818 T:4082369104 NOTICE: Local hostname: osmc
21:31:56.818 T:4082369104 NOTICE: Log File is located: /home/osmc/.kodi/temp//kodi.log
21:31:56.818 T:4082369104 NOTICE: -----------------------------------------------------------------------
21:31:56.852 T:4082369104 ERROR: DBus: Error org.freedesktop.DBus.Error.ServiceUnknown - The name org.freedesktop.UPower was not provided by any .service files
21:31:56.924 T:4082369104 NOTICE: load settings…
21:31:56.924 T:4082369104 NOTICE: AML device detected
21:31:56.996 T:4082369104 NOTICE: Found 1 Lists of Devices
21:31:56.996 T:4082369104 NOTICE: Enumerated ALSA devices:
21:31:56.996 T:4082369104 NOTICE: Device 1
21:31:56.996 T:4082369104 NOTICE: m_deviceName : default
21:31:56.996 T:4082369104 NOTICE: m_displayName : Default (AML-M8AUDIO Analog)
21:31:56.996 T:4082369104 NOTICE: m_displayNameExtra: PCM
21:31:56.996 T:4082369104 NOTICE: m_deviceType : AE_DEVTYPE_PCM
21:31:56.996 T:4082369104 NOTICE: m_channels : FL,FR,UNKNOWN1,LFE,FC,BC,BL,BR,BLOC,BROC
21:31:56.996 T:4082369104 NOTICE: m_sampleRates : 32000,44100,48000,88200,96000,176400,192000
21:31:56.996 T:4082369104 NOTICE: m_dataFormats : AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S16LE
21:31:56.996 T:4082369104 NOTICE: m_streamTypes : No passthrough capabilities
21:31:56.996 T:4082369104 NOTICE: Device 2
21:31:56.996 T:4082369104 NOTICE: m_deviceName : hdmi:CARD=AMLM8AUDIO,DEV=0
21:31:56.996 T:4082369104 NOTICE: m_displayName : AML-M8AUDIO
21:31:56.996 T:4082369104 NOTICE: m_displayNameExtra: HDMI
21:31:56.996 T:4082369104 NOTICE: m_deviceType : AE_DEVTYPE_HDMI
21:31:56.996 T:4082369104 NOTICE: m_channels : FL,FR,BL,BR,FC,LFE,SL,SR
21:31:56.996 T:4082369104 NOTICE: m_dataFormats : AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_RAW
21:31:56.997 T:4082369104 NOTICE: m_streamTypes : STREAM_TYPE_AC3,STREAM_TYPE_DTSHD,STREAM_TYPE_DTSHD_CORE,STREAM_TYPE_DTSHD_MA,STREAM_TYPE_DTS_1024,STREAM_TYPE_DTS_2048,STREAM_TYPE_DTS_512,STREAM_TYPE_EAC3,STREAM_TYPE_TRUEHD
21:31:57.006 T:4082369104 NOTICE: Loaded settings file from special://xbmc/system/advancedsettings.xml
21:31:57.006 T:4082369104 NOTICE: Contents of special://xbmc/system/advancedsettings.xml are…
<?xml version="1.0" encoding="UTF-8" ?>
540
720
false
0
30
1
524880000
5.0
/bin/sed -e 's/([0-9])[0-9]{3}./\1 C/' /sys/class/thermal/thermal_zone0/temp
21:31:57.007 T:4082369104 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
21:31:57.007 T:4082369104 NOTICE: Default Video Player: VideoPlayer
21:31:57.007 T:4082369104 NOTICE: Default Audio Player: paplayer
21:31:57.007 T:4082369104 NOTICE: Disabled debug logging due to GUI setting. Level 0.
21:31:57.007 T:4082369104 NOTICE: Log level changed to “LOG_LEVEL_NORMAL”
21:31:57.007 T:4082369104 NOTICE: CMediaSourceSettings: loading media sources from special://masterprofile/sources.xml
21:31:57.010 T:4082369104 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
21:31:57.011 T:4082369104 NOTICE: Loaded playercorefactory configuration
21:31:57.011 T:4082369104 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
21:31:57.011 T:4082369104 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
21:31:57.138 T:4082369104 NOTICE: Running database version Addons27
21:31:57.384 T:4082369104 NOTICE: ADDONS: Using repository repository.xbmc.org
21:31:57.384 T:4082369104 NOTICE: ADDONS: Using repository repository.exodusredux
21:31:57.671 T:4082369104 NOTICE: InitWindowSystem: Using EGL Implementation: amlogic
21:31:57.699 T:4082369104 ERROR: GetString: error reading /home/osmc/.kodi/userdata/disp_cap
21:31:57.700 T:4082369104 NOTICE: Desktop setting is 00192001080060.00000pstd
21:31:57.700 T:4082369104 NOTICE: Found resolution 1280 x 720 for display 0 with 1280 x 720 @ 60.000000 Hz
21:31:57.700 T:4082369104 NOTICE: Fallback resolution at 16 + 0
21:31:57.700 T:4082369104 NOTICE: Found resolution 1280 x 720 for display 0 with 1280 x 720 @ 59.940060 Hz
21:31:57.700 T:4082369104 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080i @ 60.000000 Hz
21:31:57.700 T:4082369104 NOTICE: Fallback resolution at 16 + 2
21:31:57.700 T:4082369104 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080i @ 59.940060 Hz
21:31:57.700 T:4082369104 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 60.000000 Hz
21:31:57.700 T:4082369104 NOTICE: Desktop resolution found at 16 + 4
21:31:57.700 T:4082369104 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 59.940060 Hz
21:31:57.700 T:4082369104 NOTICE: Found resolution 1280 x 720 for display 0 with 1280 x 720 @ 50.000000 Hz
21:31:57.700 T:4082369104 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080i @ 50.000000 Hz
21:31:57.700 T:4082369104 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 30.000000 Hz
21:31:57.700 T:4082369104 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 29.970030 Hz
21:31:57.700 T:4082369104 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 50.000000 Hz
21:31:57.700 T:4082369104 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 24.000000 Hz
21:31:57.700 T:4082369104 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 23.976025 Hz
21:31:57.700 T:4082369104 NOTICE: Found (1920x1080@60.000000) at 20, setting to RES_DESKTOP at 16
21:31:57.701 T:4082369104 NOTICE: Checking resolution 16
21:31:57.931 T:4082369104 NOTICE: GL_VENDOR = ARM
21:31:57.931 T:4082369104 NOTICE: GL_RENDERER = Mali-450 MP
21:31:57.931 T:4082369104 NOTICE: GL_VERSION = OpenGL ES 2.0
21:31:57.931 T:4082369104 NOTICE: GL_SHADING_LANGUAGE_VERSION = OpenGL ES GLSL ES 1.00
21:31:57.931 T:4082369104 NOTICE: GL_EXTENSIONS = GL_OES_texture_npot GL_OES_vertex_array_object GL_OES_compressed_ETC1_RGB8_texture GL_EXT_compressed_ETC1_RGB8_sub_texture GL_OES_standard_derivatives GL_OES_EGL_image GL_OES_depth24 GL_ARM_rgba8 GL_ARM_mali_shader_binary GL_OES_depth_texture GL_OES_packed_depth_stencil GL_EXT_texture_format_BGRA8888 GL_OES_vertex_half_float GL_EXT_blend_minmax GL_OES_EGL_image_external GL_OES_EGL_sync GL_OES_rgb8_rgba8 GL_EXT_multisampled_render_to_texture GL_EXT_discard_framebuffer GL_OES_get_program_binary GL_ARM_mali_program_binary GL_EXT_shader_texture_lod GL_EXT_robustness GL_OES_depth_texture_cube_map GL_KHR_debug GL_ARM_shader_framebuffer_fetch GL_ARM_shader_framebuffer_fetch_depth_stencil GL_OES_mapbuffer
21:31:58.612 T:4062180096 NOTICE: Running database version Addons27
21:31:58.614 T:4062180096 NOTICE: Running database version ViewModes6
21:31:58.616 T:4062180096 NOTICE: Running database version Textures13
21:31:58.622 T:4062180096 NOTICE: Running database version MyMusic60
21:31:58.633 T:4062180096 NOTICE: Running database version MyVideos107
21:31:58.635 T:4062180096 NOTICE: Running database version TV29
21:31:58.637 T:4062180096 NOTICE: Running database version Epg11
21:31:58.640 T:4082369104 NOTICE: start dvd mediatype detection
21:31:58.702 T:3970953984 NOTICE: Register - new cec device registered on cec->AOCEC: CEC Adapter (0000:0000)
21:31:59.232 T:4082369104 WARNING: JSONRPC: Could not parse type “Setting.Details.SettingList”
21:31:59.793 T:4082369104 NOTICE: initialize done
21:31:59.794 T:4082369104 NOTICE: Running the application…
21:31:59.803 T:4082369104 NOTICE: starting zeroconf publishing
21:31:59.803 T:4082369104 NOTICE: CWebServer[80]: Started
21:31:59.804 T:4082369104 NOTICE: starting upnp client
21:31:59.809 T:4082369104 NOTICE: starting upnp server
21:31:59.833 T:4082369104 NOTICE: starting upnp renderer
21:31:59.844 T:3725325056 NOTICE: ES: Starting UDP Event server on port 9777
21:31:59.846 T:3725325056 NOTICE: UDP: Listening on port 9777 (ipv6 : false)
21:32:03.677 T:3842765568 NOTICE: [Exodus Redux] ######################### EXODUS REDUX ############################
21:32:03.677 T:3842765568 NOTICE: [Exodus Redux] ####### CURRENT EXODUS REDUX VERSIONS REPORT ######################
21:32:03.820 T:3842765568 NOTICE: [Exodus Redux] ### EXODUS REDUX PLUGIN VERSION: 1.0.7 ###
21:32:03.820 T:3842765568 NOTICE: [Exodus Redux] ### EXODUS REDUX SCRIPT VERSION: 1.0.9 ###
21:32:03.820 T:3842765568 NOTICE: [Exodus Redux] ###############################################################
21:32:04.936 T:3869242112 WARNING: CSkinInfo: failed to load skin settings
21:32:43.861 T:4082369104 NOTICE: Log level changed to “LOG_LEVEL_DEBUG_FREEMEM”
21:32:43.861 T:4082369104 NOTICE: Enabled debug logging due to GUI setting. Level 2.
21:32:43.862 T:4082369104 DEBUG: ------ Window Init () ------
21:32:43.898 T:4082369104 DEBUG: LIRC: Update - NEW at 47119:160 0 KEY_OK_UP linux-input-layer (KEY_OK_UP)
21:32:48.662 T:4082369104 DEBUG: LIRC: Update - NEW at 51883:6c 0 KEY_DOWN linux-input-layer (KEY_DOWN)
21:32:48.662 T:4082369104 DEBUG: OnKey: 167 (0xa7, obc88) pressed, action is Down
21:32:48.729 T:4082369104 DEBUG: LIRC: Update - NEW at 51950:6c 0 KEY_DOWN_UP linux-input-layer (KEY_DOWN_UP)
21:32:49.295 T:4082369104 DEBUG: LIRC: Update - NEW at 52516:160 0 KEY_OK linux-input-layer (KEY_OK)
21:32:49.296 T:4082369104 DEBUG: OnKey: 11 (0x0b, obc244) pressed, action is Select
21:32:49.312 T:4082369104 DEBUG: LIRC: Update - NEW at 52533:160 0 KEY_OK_UP linux-input-layer (KEY_OK_UP)
21:32:50.913 T:4082369104 DEBUG: LIRC: Update - NEW at 54133:6c 0 KEY_DOWN linux-input-layer (KEY_DOWN)
21:32:50.913 T:4082369104 DEBUG: OnKey: 167 (0xa7, obc88) pressed, action is Down
21:32:50.979 T:4082369104 DEBUG: LIRC: Update - NEW at 54200:6c 0 KEY_DOWN_UP linux-input-layer (KEY_DOWN_UP)
21:32:52.579 T:4082369104 DEBUG: LIRC: Update - NEW at 55800:160 0 KEY_OK linux-input-layer (KEY_OK)
21:32:52.579 T:4082369104 DEBUG: OnKey: 11 (0x0b, obc244) pressed, action is Select
21:32:52.579 T:4082369104 DEBUG: ------ Window Init (DialogSelect.xml) ------
21:32:52.579 T:4082369104 INFO: Loading skin file: DialogSelect.xml, load type: KEEP_IN_MEMORY
21:32:52.649 T:4082369104 DEBUG: LIRC: Update - NEW at 55870:160 0 KEY_OK_UP linux-input-layer (KEY_OK_UP)
21:32:59.333 T:4082369104 DEBUG: LIRC: Update - NEW at 62553:160 0 KEY_OK linux-input-layer (KEY_OK)
21:32:59.333 T:4082369104 DEBUG: OnKey: 11 (0x0b, obc244) pressed, action is Select
21:32:59.350 T:4082369104 DEBUG: LIRC: Update - NEW at 62570:160 0 KEY_OK_UP linux-input-layer (KEY_OK_UP)
21:33:01.700 T:4082369104 DEBUG: LIRC: Update - NEW at 64920:6a 0 KEY_RIGHT linux-input-layer (KEY_RIGHT)
21:33:01.700 T:4082369104 DEBUG: OnKey: 168 (0xa8, obc87) pressed, action is Right
21:33:01.750 T:4082369104 DEBUG: LIRC: Update - NEW at 64970:6a 0 KEY_RIGHT_UP linux-input-layer (KEY_RIGHT_UP)
21:33:03.233 T:4082369104 DEBUG: LIRC: Update - NEW at 66453:160 0 KEY_OK linux-input-layer (KEY_OK)
21:33:03.233 T:4082369104 DEBUG: OnKey: 11 (0x0b, obc244) pressed, action is Select
21:33:03.283 T:4082369104 DEBUG: LIRC: Update - NEW at 66503:160 0 KEY_OK_UP linux-input-layer (KEY_OK_UP)
21:33:04.333 T:4082369104 DEBUG: LIRC: Update - NEW at 67553:6a 0 KEY_RIGHT linux-input-layer (KEY_RIGHT)
21:33:04.334 T:4082369104 DEBUG: OnKey: 168 (0xa8, obc87) pressed, action is Right
21:33:04.400 T:4082369104 DEBUG: LIRC: Update - NEW at 67620:6a 0 KEY_RIGHT_UP linux-input-layer (KEY_RIGHT_UP)
21:33:05.100 T:4082369104 DEBUG: LIRC: Update - NEW at 68320:160 0 KEY_OK linux-input-layer (KEY_OK)
21:33:05.101 T:4082369104 DEBUG: OnKey: 11 (0x0b, obc244) pressed, action is Select
21:33:05.184 T:4082369104 DEBUG: LIRC: Update - NEW at 68404:160 0 KEY_OK_UP linux-input-layer (KEY_OK_UP)
21:33:05.350 T:4082369104 DEBUG: ------ Window Deinit (DialogSelect.xml) ------
21:33:06.513 T:4082369104 DEBUG: LIRC: Update - NEW at 69733:6c 0 KEY_DOWN linux-input-layer (KEY_DOWN)
21:33:06.513 T:4082369104 DEBUG: OnKey: 167 (0xa7, obc88) pressed, action is Down
21:33:06.530 T:4082369104 DEBUG: LIRC: Update - NEW at 69750:6c 0 KEY_DOWN_UP linux-input-layer (KEY_DOWN_UP)
21:33:06.982 T:4082369104 DEBUG: LIRC: Update - NEW at 70202:160 0 KEY_OK linux-input-layer (KEY_OK)
21:33:06.983 T:4082369104 DEBUG: OnKey: 11 (0x0b, obc244) pressed, action is Select
21:33:06.985 T:4082369104 INFO: Loading skin file: FileBrowser.xml, load type: KEEP_IN_MEMORY
21:33:07.017 T:4082369104 DEBUG: ------ Window Init (FileBrowser.xml) ------
21:33:07.018 T:4082369104 DEBUG: LIRC: Update - NEW at 70238:160 0 KEY_OK_UP linux-input-layer (KEY_OK_UP)
21:33:07.025 T:3589382912 DEBUG: Thread JobWorker start, auto delete: true
21:33:09.201 T:4082369104 DEBUG: LIRC: Update - NEW at 72421:6c 0 KEY_DOWN linux-input-layer (KEY_DOWN)
21:33:09.201 T:4082369104 DEBUG: OnKey: 167 (0xa7, obc88) pressed, action is Down
21:33:09.284 T:4082369104 DEBUG: LIRC: Update - NEW at 72504:6c 0 KEY_DOWN_UP linux-input-layer (KEY_DOWN_UP)
21:33:10.568 T:4082369104 DEBUG: LIRC: Update - NEW at 73787:6c 0 KEY_DOWN linux-input-layer (KEY_DOWN)
21:33:10.568 T:4082369104 DEBUG: OnKey: 167 (0xa7, obc88) pressed, action is Down
21:33:10.634 T:4082369104 DEBUG: LIRC: Update - NEW at 73854:6c 0 KEY_DOWN_UP linux-input-layer (KEY_DOWN_UP)
21:33:11.284 T:4082369104 DEBUG: LIRC: Update - NEW at 74504:6c 0 KEY_DOWN linux-input-layer (KEY_DOWN)
21:33:11.284 T:4082369104 DEBUG: OnKey: 167 (0xa7, obc88) pressed, action is Down
21:33:11.318 T:4082369104 DEBUG: LIRC: Update - NEW at 74537:6c 0 KEY_DOWN_UP linux-input-layer (KEY_DOWN_UP)
21:33:16.834 T:4082369104 DEBUG: LIRC: Update - NEW at 80054:67 0 KEY_UP linux-input-layer (KEY_UP)
21:33:16.835 T:4082369104 DEBUG: OnKey: 166 (0xa6, obc89) pressed, action is Up
21:33:16.918 T:4082369104 DEBUG: LIRC: Update - NEW at 80138:67 0 KEY_UP_UP linux-input-layer (KEY_UP_UP)
21:33:17.251 T:4082369104 DEBUG: LIRC: Update - NEW at 80471:67 0 KEY_UP linux-input-layer (KEY_UP)
21:33:17.251 T:4082369104 DEBUG: OnKey: 166 (0xa6, obc89) pressed, action is Up
21:33:17.268 T:4082369104 DEBUG: LIRC: Update - NEW at 80488:67 0 KEY_UP_UP linux-input-layer (KEY_UP_UP)
21:33:18.751 T:4082369104 DEBUG: LIRC: Update - NEW at 81971:6c 0 KEY_DOWN linux-input-layer (KEY_DOWN)
21:33:18.751 T:4082369104 DEBUG: OnKey: 167 (0xa7, obc88) pressed, action is Down
21:33:18.768 T:4082369104 DEBUG: LIRC: Update - NEW at 81988:6c 0 KEY_DOWN_UP linux-input-layer (KEY_DOWN_UP)
21:33:19.035 T:4082369104 DEBUG: LIRC: Update - NEW at 82254:6c 0 KEY_DOWN linux-input-layer (KEY_DOWN)
21:33:19.035 T:4082369104 DEBUG: OnKey: 167 (0xa7, obc88) pressed, action is Down
21:33:19.051 T:4082369104 DEBUG: LIRC: Update - NEW at 82271:6c 0 KEY_DOWN_UP linux-input-layer (KEY_DOWN_UP)
21:33:19.284 T:4082369104 DEBUG: LIRC: Update - NEW at 82504:6c 0 KEY_DOWN linux-input-layer (KEY_DOWN)
21:33:19.285 T:4082369104 DEBUG: OnKey: 167 (0xa7, obc88) pressed, action is Down
21:33:19.301 T:4082369104 DEBUG: LIRC: Update - NEW at 82521:6c 0 KEY_DOWN_UP linux-input-layer (KEY_DOWN_UP)
21:33:19.768 T:4082369104 DEBUG: LIRC: Update - NEW at 82988:6c 0 KEY_DOWN linux-input-layer (KEY_DOWN)
21:33:19.768 T:4082369104 DEBUG: OnKey: 167 (0xa7, obc88) pressed, action is Down
21:33:19.801 T:4082369104 DEBUG: LIRC: Update - NEW at 83021:6c 0 KEY_DOWN_UP linux-input-layer (KEY_DOWN_UP)
21:33:20.401 T:4082369104 DEBUG: LIRC: Update - NEW at 83621:160 0 KEY_OK linux-input-layer (KEY_OK)
21:33:20.401 T:4082369104 DEBUG: OnKey: 11 (0x0b, obc244) pressed, action is Select
21:33:20.402 T:3589382912 DEBUG: OpenDir: Using authentication url smb://
21:33:20.902 T:4082369104 DEBUG: ------ Window Init (DialogBusy.xml) ------
21:33:20.904 T:4082369104 DEBUG: LIRC: Update - NEW at 84124:160 0 KEY_OK_UP linux-input-layer (KEY_OK_UP)
21:33:22.022 T:4082369104 DEBUG: ------ Window Deinit (DialogBusy.xml) ------
21:33:22.336 T:4082369104 DEBUG: LIRC: Update - NEW at 85555:6c 0 KEY_DOWN linux-input-layer (KEY_DOWN)
21:33:22.336 T:4082369104 DEBUG: OnKey: 167 (0xa7, obc88) pressed, action is Down
21:33:22.370 T:4082369104 DEBUG: LIRC: Update - NEW at 85589:6c 0 KEY_DOWN_UP linux-input-layer (KEY_DOWN_UP)
21:33:22.801 T:4082369104 DEBUG: LIRC: Update - NEW at 86021:160 0 KEY_OK linux-input-layer (KEY_OK)
21:33:22.801 T:4082369104 DEBUG: OnKey: 11 (0x0b, obc244) pressed, action is Select
21:33:22.802 T:3589382912 DEBUG: OpenDir: Using authentication url smb://WORKGROUP/
21:33:22.851 T:4082369104 DEBUG: LIRC: Update - NEW at 86070:160 0 KEY_OK_UP linux-input-layer (KEY_OK_UP)
21:33:23.751 T:4082369104 DEBUG: LIRC: Update - NEW at 86970:6c 0 KEY_DOWN linux-input-layer (KEY_DOWN)
21:33:23.751 T:4082369104 DEBUG: OnKey: 167 (0xa7, obc88) pressed, action is Down
21:33:23.818 T:4082369104 DEBUG: LIRC: Update - NEW at 87037:6c 0 KEY_DOWN_UP linux-input-layer (KEY_DOWN_UP)
21:33:24.168 T:4082369104 DEBUG: LIRC: Update - NEW at 87387:6c 0 KEY_DOWN linux-input-layer (KEY_DOWN)
21:33:24.168 T:4082369104 DEBUG: OnKey: 167 (0xa7, obc88) pressed, action is Down
21:33:24.201 T:4082369104 DEBUG: LIRC: Update - NEW at 87421:6c 0 KEY_DOWN_UP linux-input-layer (KEY_DOWN_UP)
21:33:24.668 T:4082369104 DEBUG: LIRC: Update - NEW at 87887:160 0 KEY_OK linux-input-layer (KEY_OK)
21:33:24.668 T:4082369104 DEBUG: OnKey: 11 (0x0b, obc244) pressed, action is Select
21:33:24.669 T:3589382912 DEBUG: OpenDir: Using authentication url smb://SCOTT/
21:33:25.169 T:4082369104 DEBUG: ------ Window Init (DialogBusy.xml) ------
21:33:25.171 T:4082369104 DEBUG: LIRC: Update - NEW at 88390:160 0 KEY_OK_UP linux-input-layer (KEY_OK_UP)
21:33:26.687 T:3589382912 ERROR: SMBDirectory->GetDirectory: Unable to open directory : ‘smb://SCOTT/’
unix_err:‘6e’ error : ‘Connection timed out’
21:33:26.687 T:4082369104 DEBUG: ------ Window Init (DialogConfirm.xml) ------
21:33:26.687 T:4082369104 INFO: Loading skin file: DialogConfirm.xml, load type: KEEP_IN_MEMORY
21:33:26.953 T:4082369104 DEBUG: ------ Window Deinit (DialogBusy.xml) ------
21:33:34.870 T:4082369104 DEBUG: LIRC: Update - NEW at 98089:160 0 KEY_OK linux-input-layer (KEY_OK)
21:33:34.870 T:4082369104 DEBUG: OnKey: 11 (0x0b, obc244) pressed, action is Select
21:33:34.937 T:4082369104 DEBUG: LIRC: Update - NEW at 98156:160 0 KEY_OK_UP linux-input-layer (KEY_OK_UP)
21:33:35.120 T:4082369104 DEBUG: ------ Window Deinit (DialogConfirm.xml) ------
21:33:35.120 T:4082369104 ERROR: GetDirectory - Error getting smb://SCOTT/
21:33:35.121 T:4082369104 ERROR: CGUIDialogFileBrowser::GetDirectory(smb://SCOTT/) failed
21:33:35.121 T:3589382912 DEBUG: OpenDir: Using authentication url smb://WORKGROUP/
21:34:05.128 T:3589382912 DEBUG: Thread JobWorker 3589382912 terminating (autodelete)
You can see how to submit a useful support request here.
Unfortunately the logs you’ve provided aren’t really readable.
Hello Scotty, Hope you don’t mind me piggybacking here but I’m in a similar position with Vero.
Like you I can connect with Rasp pi and Android box, but when I attempt to browse to a shared (windows/SMB) folder, Vero also tells me ‘Operation not permitted’
One of these folder asks me for a User/pass which doesn’t exist afaik. The shared folders are not all on the same pc, they’re spread over 3, 2 running Win10 and one XP. Its the XP one that wants a password.
PS, Dunno why I’m Jill… I’m Kirk, Jills my wife !
To browser shares you would need to limit Samba Protocol to SMB1 which has been disabled for security reasons. Suggest you check up here
Thank you. I did read that. Maybe the info i need is in there, but its not so obvious to a novice. That it works in other devices to me suggests “it” is ok and the other side (Vero) is what needs attention. But If I knew what exactly what this is suggesting to do, I’d try it.
It’s very early days. Maybe what Scotty uncovers will help.
Yes, I agree the Vero needs attention. You need to enable SMB1 on the Vero as it is disabled for safety reasons.
I have changed the SMB protocol on the Vero to (0,1,2,3) none of which has solved my connection problem.
I have also allowed SMBv1 on my computer which is inadvisable for security purposes and I still cannot connect.
Personally I would disable SMB1 again and switch to use kernel based mounting (e.g. via autofs) as it is more stable and performant.
I think that is beyond my capabilities.
I bought the Vero because it was supposed to be fool proof and wasn’t expecting all this extra frustration
Set both devices to smbv1, reboot both devices, give them several minutes to locate/negotiate with each other.
We’re happy to get this working for you.
Unfortunately SMBv1 is largely deprecated (or at least should be) since May 2017; so you will find the same issues with other new devices.
If you do need to use SMBv1 for the time being, this should still be possible.
More than willing to lead you through the steps that are necessary if you are interested.
But you can also stick to your current approach. As long as both devices are in the same LAN segment and SMB Client is limited to SMB1 it should see the SMB share
