Cannot connect to SMB shares
I just received my Vero 4k+ that is replacing a Raspberry pi3 and I am unable to connect it will not see all my shared folders on my computer through SMB. (Windows 10)
The workgroup folder sees my computer but when I click on it I get an error screen saying ‘Operation not permitted’
I have turned off windows firewall, uninstalled antivirus program but still no luck.
3 Raspberry pi’s and one android based tv running Kodi and have no issues connecting to SMB share from my computer.
Any help would be appreciated
Have a look here first:
You may find just copying your sources.xml from one of the other devices sets you up.
Thanks grahamh but that unfortunately didn’t work.
I was able to successfully transfer my sources.xml over to the Vero. My sources now show up in the Vero but when I attempt to access I get an error screen saying ‘Operation not permitted’ and then when I hit OK I get a remote share screen saying ‘Couldn’t connect to network server’
Can you show us the sources.xml (feel free to remove passwords)?
Shouldn’t passwords be in passwords.xml?
Depends how it’s added.
<sources>
    <programs>
        <default pathversion="1"></default>
    </programs>
    <video>
        <source>
            <name>Videos</name>
            <path pathversion="1">/storage/videos/</path>
            <allowsharing>true</allowsharing>
        </source>
        <source>
            <name>TV Shows</name>
            <path pathversion="1">/storage/tvshows/</path>
        </source>
        <source>
            <name>TV Shows I Drive</name>
            <path pathversion="1">smb://SCOTT/TV Shows I Drive/</path>
        </source>
        <source>
            <name>MoviesB</name>
            <path pathversion="1">smb://SCOTT/MoviesB/</path>
        </source>
        <source>
            <name>MoviesE</name>
            <path pathversion="1">smb://SCOTT/MoviesE/Movies/</path>
        </source>
        <source>
            <name>MoviesF</name>
            <path pathversion="1">smb://SCOTT/test/Movies/</path>
        </source>
        <source>
            <name>MoviesG</name>
            <path pathversion="1">smb://SCOTT/MoviesG/Movies/</path>
        </source>
        <source>
            <name>MoviesH</name>
            <path pathversion="1">smb://SCOTT/MoviesH/Movies/</path>
        </source>
        <source>
            <name>MoviesJ</name>
            <path pathversion="1">smb://SCOTT/J/MoviesJ/</path>
        </source>
        <source>
            <name>MoviesK</name>
            <path pathversion="1">smb://SCOTT/K/MoviesK/</path>
        </source>
        <source>
            <name>MoviesL</name>
            <path pathversion="1">smb://SCOTT/L/MoviesL/</path>
        </source>
        <source>
            <name>TV Shows A</name>
            <path pathversion="1">smb://SCOTT/TV Shows A/</path>
        </source>
        <source>
            <name>MoviesA</name>
            <path pathversion="1">smb://SCOTT/A/MoviesA/</path>
        </source>
    </video>
    <music>
        <source>
            <name>Music</name>
            <path pathversion="1">/storage/music/</path>
        </source>
    </music>
    <pictures>
        <source>
            <name>Pictures</name>
            <path pathversion="1">/storage/pictures/</path>
        </source>
    </pictures>
    <files>
        <source>
            <path pathversion="1">smb://SCOTT/MoviesA/Movies/</path>
        </source>
    </files>
    <games>
    </games>
</sources>
EDIT: I fixed the formatting for you, and removed some questionable sources.
Try using the IP of the system instead of the name, that may help.
Ok, I tried replacing SCOTT with the ip of my computer 192.168.1.109
Sadly this didn’t work either
Can you check SMB version under Settings -> Services on both Pi and Vero?
Can you check what version of OSMC you are using on your Pi?
We’ll get this working for you – just need a bit more info.
Vero is set at SMBv3
I am using Libreelec on my pi and SMB is set to ‘none’
I will try ‘none’ on the Vero and see if that sorts things out
Setting to ‘none’ on the Vero did not work either
A couple of things to try from commend line. (I assume you can ssh in?)
ping -c 4 scott
ping -c 4 192.168.1.109
smbclient --list=192.168.1.109
You will get prompted for a password, try just hitting ENTER.
What am I looking for? I can’t seem to copy the string from putty
I am getting essentially 4 packets sent and 4 packets received with 0% packet loss
That’s 3 different commands. The first 2 pings should show no packet loss. The smbclient command will show info that may give us more ideas of what’s wrong.
-bash: smbclient: command not found
Opps, sorry. You need to install it first:
sudo apt install smbclient
and just answer Y
Not sure what you mean by install it or how to, that may be beyond my limited knowledge of ssh and putty
The first thing we should be requesting is a log via My OSMC; not asking for CLI steps.
I gave you the command to install it.
