Cannot enable Simple IPTV Addon
I am not able to enable any of the PVR addons to be honest, I have never needed to, am I missing any packages?
19:55:03.941 T:4074992208 DEBUG: ADDON: Dll Initializing - PVR IPTV Simple Client 19:55:03.941 T:4074992208 DEBUG: ------ Window Init (DialogConfirm.xml) ------ 19:55:04.219 T:4074992208 DEBUG: LIRC: Update - NEW at 114086136:160 0 KEY_OK_UP linux-input-layer (KEY_OK_UP) 19:55:31.151 T:4074992208 DEBUG: LIRC: Update - NEW at 114113068:160 0 KEY_OK linux-input-layer (KEY_OK) 19:55:31.151 T:4074992208 DEBUG: OnKey: 11 (0x0b, obc244) pressed, action is Select 19:55:31.151 T:4034917120 INFO: CActiveAESink::OpenSink - initialize sink 19:55:31.152 T:4034917120 DEBUG: CActiveAESink::OpenSink - trying to open device ALSA:hdmi:CARD=AMLM8AUDIO,DEV=0 19:55:31.152 T:4034917120 INFO: CAESinkALSA::Initialize - Requested layout: FL,FR 19:55:31.152 T:4034917120 INFO: CAESinkALSA::Initialize - set digital_codec 0 19:55:31.152 T:4034917120 DEBUG: CAESinkALSA::Initialize -- unmuting HDMI 19:55:31.152 T:4034917120 INFO: CAESinkALSA::Initialize - Attempting to open device "@:CARD=AMLM8AUDIO,DEV=0" with 19:55:31.156 T:4034917120 INFO: CAESinkALSA::Initialize - Opened device "default:CARD=AMLM8AUDIO" 19:55:31.158 T:4034917120 INFO: CAESinkALSA::InitializeHW - Your hardware does not support AE_FMT_FLOAT, trying other formats 19:55:31.158 T:4034917120 INFO: CAESinkALSA::InitializeHW - Using data format AE_FMT_S32NE 19:55:31.158 T:4034917120 DEBUG: CAESinkALSA::InitializeHW - Request: periodSize 2048, bufferSize 8192 19:55:31.159 T:4034917120 DEBUG: CAESinkALSA::InitializeHW - Got: periodSize 2048, bufferSize 8192 19:55:31.159 T:4034917120 DEBUG: CAESinkALSA::InitializeHW - Setting timeout to 186 ms 19:55:31.159 T:4034917120 INFO: CAESinkALSA::Initialize - setting default aud_ch to 0 19:55:31.160 T:4034917120 DEBUG: CAESinkALSA::GetChannelLayout - Input Channel Count: 2 Output Channel Count: 2 19:55:31.160 T:4034917120 DEBUG: CAESinkALSA::GetChannelLayout - Requested Layout: FL,FR 19:55:31.160 T:4034917120 DEBUG: CAESinkALSA::GetChannelLayout - Got Layout: FL,FR (ALSA: none) (CEA: 0) 19:55:31.160 T:4034917120 DEBUG: CActiveAESink::OpenSink - ALSA Initialized: 19:55:31.160 T:4034917120 DEBUG: Output Device : AML-M8AUDIO 19:55:31.160 T:4034917120 DEBUG: Sample Rate : 44100 19:55:31.160 T:4034917120 DEBUG: Sample Format : AE_FMT_S32NE 19:55:31.160 T:4034917120 DEBUG: Channel Count : 2 19:55:31.160 T:4034917120 DEBUG: Channel Layout: FL,FR 19:55:31.160 T:4034917120 DEBUG: Frames : 2048 19:55:31.160 T:4034917120 DEBUG: Frame Size : 8 19:55:31.401 T:4074992208 DEBUG: ------ Window Deinit (DialogConfirm.xml) ------ 19:55:31.401 T:4074992208 ERROR: UpdateAddons - failed to create add-on PVR IPTV Simple Client, status = 6
Not sure what I am missing something quite basic, other ubuntu based stuff has a .deb package with that particular addon, whats the method in osmc?
A full log would help. It’s a bit hard to see what’s going on with your snippet and formatting.
