Hi Guys
I cannot mount a NFS share.
Logs here:
https://paste.osmc.tv/efoxovakec
showmount -e 192.168.0.3 shows:
osmc@osmc:~$ showmount -e 192.168.0.3
Export list for 192.168.0.3:
/home/kris/Movies 192.168.0.3
fstab file:
osmc@osmc:~$ cat /etc/fstab
# rootfs is not mounted in fstab as we do it via initramfs. Uncomment for remount (slower boot)
#/dev/vero-nand/root / ext4 defaults,noatime 0 0
192.168.0.3:/home/kris/Movies /mnt/NAS-Movies nfs noauto,x-systemd.automount 0 0
osmc@osmc:~$
Any thoughts?
Moved you post to a new topic, to keep the wiki posts tidy.
Does it mount if you issue the following command:
sudo mount /mnt/NAS-Movies
If it does, try enabling wait for network in MyOSMC.
Thanks Tom.
Have you tried mounting it manually ?
mkdir /mnt/test
mount -t nfs 192.168.0.3:/home/kris/Movies /mnt/test
To see if you can mount it.
The one thing I never do with NFS target/directories is using any special char in the directory.
I havent… but just did.
osmc@osmc:/mnt$ sudo mount -t nfs 192.168.0.3:/home/kris/Movies /mnt/NAS-Movies
mount.nfs: access denied by server while mounting 192.168.0.3:/home/kris/Movies
osmc@osmc:/mnt$
So - you have your answer there. Check your Server settings
Sorry im not really familiar with UNIX
What would I check Smurphy?
exports file?
It has this:
/home/kris/Movies 192.168.0.3(rw,sync,root_squash,subtree_check)
So that gives access to IP 192.168.0.3 but your OSMC is 192.168.0.12
Thanks! didnt realise thats the CLIENT IP thats needed, not the server IP.
Its working now. Sorry for wasting your time
No worries, education is never a waste of time.
BTW - what is the IP of the Server, and what is the IP of the Kodi-client? Maybe that’s what is wrong?
Update: saw that this was already dealt with, while I wrote it down
Yep its visible in the SSH Client.
How do I make this share visible inside the GUI so that I can browse its movies?
browse to root filesystem, mnt, NAS-Movies
Thanks Tom.
