Cannot mount NFS share in GUI (works in terminal)
Problem:
I cannot mount an NFS share, nor an samba share.
#NFS
I have enabled NFS on my synology fileshare. These days you dont need to edit a file via SSH in synology, they have an option in the GUI to allow the insecure parameter.
I verified that NFS works by SSHing to the rasberry pi, and running command:
osmc@hallonpi:~$ sudo -i
root@hallonpi:~# mount 192.168.0.10:/volume1/fileserver /mnt/
root@hallonpi:~# ls /mnt/
recycle backups downloads homefolders mounted upload
@eaDir code encrypted lost+found tmp
applications documents games media unsorted
root@hallonpi:~# umount /mnt/
So seems to work fine.
So what happens when I try in the GUI?
Well I go to: Videos -> Files -> Add videos -> Browse -> Network File System (NFS)
Here it lists my NFS server with IP 192.168.0.10
I select it, and get to the next level where it says
/volume1/fileserver
I mark it and click it, but nothing happens. The click sound is played but nothing more.
#SMB
So I figured that I would try samba instead. Not as fast and good as NFS but lets try it.
I go back a few steps and select Windows network (SMB) instead
It lists “WORKGROUP” and under it is my samba server (same as for NFS)
I click it, and get error “Operation not permitted”
There is a username and password required to access to samba share, but I would expect to get prompted for it.
“Operation not permitted” sounds more of a local permission issue.
https://discourse.osmc.tv/t/how-to-obtain-provide-necessary-info-for-a-useful-support-request-includes-current-versions/5507
When I try to access your link that I assume holds som information on how I can give you the exact versions etc I am running I get the error
“Sorry, you don’t have access to that topic”
Maybe you can include the relevant parts in a reply here so that I can be sure to include the needed information to get help?
Thanks!
Try this link How to submit a useful support request
Basically it is the top pinned thread that you see if you press “latest”
