hi all,
I cannot select hifiberry dac as my primary audio source. the strange thing is, that it has worked already, then after a reboot it stopped. not i only get to chose between hdmi, analogue and hdmi&analogue. Can someone help?
thank you
Markus
here’s some outputs:
osmc@osmc:~$ sudo aplay -l
**** list of devices (PLAYBACK) ****
slot 1: sndrpihifiberry [snd_rpi_hifiberry_dac], device 0: HifiBerry DAC HiFi pcm5102a-hifi-0
Sub-device: 1/1
Sub-device #0: subdevice #0
lsmod
regmap_mmio 4274 1 snd_soc_bcm2708_i2s
snd_soc_core 195033 3 snd_soc_hifiberry_dac,snd_soc_pcm5102a,snd_soc_bcm2708_i2s
snd_compress 9334 1 snd_soc_core
snd_pcm_dmaengine 5989 1 snd_soc_core
dmesg
osmc@osmc:~$ dmesg
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Initializing cgroup subsys cpu
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 4.1.5-1-osmc (root@rpi2) (gcc version 4.9.2 (Raspbian 4.9.2-10) ) #1 PREEMPT Wed Aug 19 22:08:45 UTC 2015
[ 0.000000] CPU: ARMv6-compatible processor [410fb767] revision 7 (ARMv7), cr=00c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
[ 0.000000] Machine model: Raspberry Pi Model B Rev 2
[ 0.000000] cma: Reserved 8 MiB at 0x16800000
[ 0.000000] Memory policy: Data cache writeback
[ 0.000000] On node 0 totalpages: 94208
[ 0.000000] free_area_init_node: node 0, pgdat c0a04adc, node_mem_map d64b7000
[ 0.000000] Normal zone: 828 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 94208 pages, LIFO batch:31
[ 0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
[ 0.000000] pcpu-alloc: [0] 0
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 93380
[ 0.000000] Kernel command line: dma.dmachans=0x7f35 bcm2708_fb.fbwidth=720 bcm2708_fb.fbheight=480 bcm2708.boardrev=0xd bcm2708.serial=0x17c07e85 smsc95xx.macaddr=B8:27:EB:C0:7E:85 bcm2708_fb.fbswap=1 sdhci-bcm2708.emmc_clock_freq=250000000 vc_mem.mem_base=0x1ec00000 vc_mem.mem_size=0x20000000 root=/dev/sda1 rootfstype=ext4 rootwait quiet osmcdev=rbp1
[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Memory: 353800K/376832K available (7648K kernel code, 503K rwdata, 1776K rodata, 332K init, 720K bss, 14840K reserved, 8192K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
vmalloc : 0xd7800000 - 0xff000000 ( 632 MB)
lowmem : 0xc0000000 - 0xd7000000 ( 368 MB)
modules : 0xbf000000 - 0xc0000000 ( 16 MB)
.text : 0xc0008000 - 0xc093c28c (9425 kB)
.init : 0xc093d000 - 0xc0990000 ( 332 kB)
.data : 0xc0990000 - 0xc0a0ddcc ( 504 kB)
.bss : 0xc0a0ddcc - 0xc0ac1f30 ( 721 kB)
[ 0.000000] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] NR_IRQS:522
[ 0.000000] clocksource stc: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns
[ 0.000015] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 2147483647500ns
[ 0.000055] Switching to timer-based delay loop, resolution 1000ns
[ 0.000331] Console: colour dummy device 80x30
[ 0.000540] console [tty0] enabled
[ 0.000566] Calibrating delay loop (skipped), value calculated using timer frequency… 2.00 BogoMIPS (lpj=10000)
[ 0.000594] pid_max: default: 32768 minimum: 301
[ 0.000920] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.000945] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.001942] Initializing cgroup subsys blkio
[ 0.001983] Initializing cgroup subsys memory
[ 0.002018] Initializing cgroup subsys devices
[ 0.002046] Initializing cgroup subsys freezer
[ 0.002072] Initializing cgroup subsys net_cls
[ 0.002150] CPU: Testing write buffer coherency: ok
[ 0.002224] ftrace: allocating 18354 entries in 54 pages
[ 0.095894] Setting up static identity map for 0x81c0 - 0x821c
[ 0.098330] devtmpfs: initialized
[ 0.107625] VFP support v0.3: implementor 41 architecture 1 part 20 variant b rev 5
[ 0.108188] clocksource jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.109973] pinctrl core: initialized pinctrl subsystem
[ 0.110842] NET: Registered protocol family 16
[ 0.116038] DMA: preallocated 4096 KiB pool for atomic coherent allocations
[ 0.145625] cpuidle: using governor ladder
[ 0.175672] cpuidle: using governor menu
[ 0.175900] bcm2708.uart_clock = 3000000
[ 0.182721] hw-breakpoint: found 6 breakpoint and 1 watchpoint registers.
[ 0.182751] hw-breakpoint: maximum watchpoint size is 4 bytes.
[ 0.182930] Serial: AMBA PL011 UART driver
[ 0.183203] 20201000.uart: ttyAMA0 at MMIO 0x20201000 (irq = 83, base_baud = 0) is a PL011 rev2
[ 0.184019] bcm2835-mbox 2000b880.mailbox: mailbox enabled
[ 0.248055] bcm2708-dmaengine 20007000.dma: DMA legacy API manager at f2007000, dmachans=0x7f35
[ 0.248950] bcm2708-dmaengine 20007000.dma: Load BCM2835 DMA engine driver
[ 0.248974] bcm2708-dmaengine 20007000.dma: dma_debug:0
[ 0.249658] SCSI subsystem initialized
[ 0.249997] usbcore: registered new interface driver usbfs
[ 0.250130] usbcore: registered new interface driver hub
[ 0.250327] usbcore: registered new device driver usb
[ 0.251262] raspberrypi-firmware soc:firmware: Attached to firmware from 2015-08-20 17:56
[ 0.278487] Switched to clocksource stc
[ 0.327462] FS-Cache: Loaded
[ 0.327877] CacheFiles: Loaded
[ 0.347228] NET: Registered protocol family 2
[ 0.348711] TCP established hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.348815] TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.348916] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.349023] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.349061] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.349398] NET: Registered protocol family 1
[ 0.350044] RPC: Registered named UNIX socket transport module.
[ 0.350073] RPC: Registered udp transport module.
[ 0.350085] RPC: Registered tcp transport module.
[ 0.350096] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.350716] hw perfevents: enabled with armv6_1176 PMU driver, 3 counters available
[ 0.352273] futex hash table entries: 256 (order: -1, 3072 bytes)
[ 0.352424] audit: initializing netlink subsys (disabled)
[ 0.352516] audit: type=2000 audit(0.290:1): initialized
[ 0.368631] VFS: Disk quotas dquot_6.6.0
[ 0.369025] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.371481] FS-Cache: Netfs ‘nfs’ registered for caching
[ 0.373173] NFS: Registering the id_resolver key type
[ 0.373264] Key type id_resolver registered
[ 0.373281] Key type id_legacy registered
[ 0.377578] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ 0.378002] io scheduler noop registered
[ 0.378790] io scheduler bfq registered (default)
[ 0.378811] BFQ I/O-scheduler version: v7r7
[ 0.381260] BCM2708FB: allocated DMA memory 56c00000
[ 0.381338] BCM2708FB: allocated DMA channel 0 @ f2007000
[ 0.387281] Console: switching to colour frame buffer device 90x30
[ 0.393114] vc-cma: Videocore CMA driver
[ 0.393143] vc-cma: vc_cma_base = 0x00000000
[ 0.393156] vc-cma: vc_cma_size = 0x00000000 (0 MiB)
[ 0.393167] vc-cma: vc_cma_initial = 0x00000000 (0 MiB)
[ 0.393535] vc-mem: phys_addr:0x00000000 mem_base=0x1ec00000 mem_size:0x20000000(512 MiB)
[ 0.414412] brd: module loaded
[ 0.424186] loop: module loaded
[ 0.425317] vchiq: vchiq_init_state: slot_zero = 0xd6c80000, is_master = 0
[ 0.427651] Loading iSCSI transport class v2.0-870.
[ 0.429111] usbcore: registered new interface driver smsc95xx
[ 0.429235] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 0.629796] Core Release: 2.80a
[ 0.629835] Setting default values for core params
[ 0.629864] Finished setting default values for core params
[ 0.830063] Using Buffer DMA mode
[ 0.830092] Periodic Transfer Interrupt Enhancement - disabled
[ 0.830105] Multiprocessor Interrupt Enhancement - disabled
[ 0.830118] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 0.830135] Dedicated Tx FIFOs mode
[ 0.830691] WARN::dwc_otg_hcd_init:1047: FIQ DMA bounce buffers: virt = 0xd6c14000 dma = 0x56c14000 len=9024
[ 0.830729] FIQ FSM acceleration enabled for :
Non-periodic Split Transactions
Periodic Split Transactions
High-Speed Isochronous Endpoints
[ 0.830760] dwc_otg: Microframe scheduler enabled
[ 0.830839] WARN::hcd_init_fiq:412: FIQ on core 0 at 0xc053a190
[ 0.830861] WARN::hcd_init_fiq:413: FIQ ASM at 0xc053a46c length 36
[ 0.830892] WARN::hcd_init_fiq:438: MPHI regs_base at 0xd7896000
[ 0.830951] dwc_otg 20980000.usb: DWC OTG Controller
[ 0.831013] dwc_otg 20980000.usb: new USB bus registered, assigned bus number 1
[ 0.831091] dwc_otg 20980000.usb: irq 32, io mem 0x00000000
[ 0.831134] Init: Port Power? op_state=1
[ 0.831146] Init: Power Port (0)
[ 0.831527] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.831554] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.831571] usb usb1: Product: DWC OTG Controller
[ 0.831588] usb usb1: Manufacturer: Linux 4.1.5-1-osmc dwc_otg_hcd
[ 0.831603] usb usb1: SerialNumber: 20980000.usb
[ 0.832834] hub 1-0:1.0: USB hub found
[ 0.832934] hub 1-0:1.0: 1 port detected
[ 0.833817] dwc_otg: FIQ enabled
[ 0.833840] dwc_otg: NAK holdoff enabled
[ 0.833852] dwc_otg: FIQ split-transaction FSM enabled
[ 0.833904] Module dwc_common_port init
[ 0.834428] usbcore: registered new interface driver usb-storage
[ 0.834855] mousedev: PS/2 mouse device common for all mice
[ 0.835778] bcm2835-cpufreq: min=700000 max=950000
[ 0.836210] sdhci: Secure Digital Host Controller Interface driver
[ 0.836229] sdhci: Copyright© Pierre Ossman
[ 0.836823] mmc-bcm2835 20300000.mmc: mmc_debug:0 mmc_debug2:0
[ 0.836850] mmc-bcm2835 20300000.mmc: DMA channels allocated
[ 0.868912] sdhci-pltfm: SDHCI platform and OF driver helper
[ 0.869570] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.869762] hidraw: raw HID events driver © Jiri Kosina
[ 0.870063] usbcore: registered new interface driver usbhid
[ 0.870081] usbhid: USB HID core driver
[ 0.870508] Initializing XFRM netlink socket
[ 0.870596] NET: Registered protocol family 17
[ 0.870824] Key type dns_resolver registered
[ 0.880138] registered taskstats version 1
[ 0.880557] vc-sm: Videocore shared memory driver
[ 0.880585] [vc_sm_connected_init]: start
[ 0.883855] [vc_sm_connected_init]: end - returning 0
[ 0.890286] Waiting for root device /dev/sda1…
[ 0.937871] mmc0: host does not support reading read-only switch, assuming write-enable
[ 0.941961] mmc0: new high speed SDHC card at address e624
[ 0.942792] mmcblk0: mmc0:e624 SU16G 14.8 GiB
[ 0.945516] mmcblk0: p1
[ 1.028725] Indeed it is in host mode hprt0 = 00021501
[ 1.208558] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ 1.208779] Indeed it is in host mode hprt0 = 00001101
[ 1.408974] usb 1-1: New USB device found, idVendor=0424, idProduct=9512
[ 1.409026] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1.410412] hub 1-1:1.0: USB hub found
[ 1.410597] hub 1-1:1.0: 3 ports detected
[ 1.688570] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[ 1.788983] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[ 1.789016] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1.792327] smsc95xx v1.0.4
[ 1.853471] smsc95xx 1-1.1:1.0 eth0: register ‘smsc95xx’ at usb-20980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:c0:7e:85
[ 1.948566] usb 1-1.2: new high-speed USB device number 4 using dwc_otg
[ 2.050860] usb 1-1.2: New USB device found, idVendor=0781, idProduct=556b
[ 2.050892] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2.050911] usb 1-1.2: Product: Cruzer Edge
[ 2.050927] usb 1-1.2: Manufacturer: SanDisk
[ 2.050942] usb 1-1.2: SerialNumber: 20043514911DD6436DD2
[ 2.052179] usb-storage 1-1.2:1.0: USB Mass Storage device detected
[ 2.052964] scsi host0: usb-storage 1-1.2:1.0
[ 2.148571] usb 1-1.3: new high-speed USB device number 5 using dwc_otg
[ 2.250480] usb 1-1.3: New USB device found, idVendor=05e3, idProduct=0608
[ 2.250517] usb 1-1.3: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 2.250535] usb 1-1.3: Product: USB2.0 Hub
[ 2.251971] hub 1-1.3:1.0: USB hub found
[ 2.252458] hub 1-1.3:1.0: 4 ports detected
[ 2.528573] usb 1-1.3.1: new full-speed USB device number 6 using dwc_otg
[ 2.653159] usb 1-1.3.1: New USB device found, idVendor=0a12, idProduct=0001
[ 2.653194] usb 1-1.3.1: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[ 2.653212] usb 1-1.3.1: Product: CSR8510 A10
[ 2.728576] usb 1-1.3.3: new high-speed USB device number 7 using dwc_otg
[ 2.830450] usb 1-1.3.3: New USB device found, idVendor=0ccd, idProduct=00b2
[ 2.830483] usb 1-1.3.3: New USB device strings: Mfr=3, Product=1, SerialNumber=2
[ 2.830502] usb 1-1.3.3: Product: Cinergy HTC Stick
[ 2.830517] usb 1-1.3.3: Manufacturer: TERRATEC
[ 2.830533] usb 1-1.3.3: SerialNumber: 123456789ABCD
[ 2.908567] usb 1-1.3.4: new high-speed USB device number 8 using dwc_otg
[ 3.010479] usb 1-1.3.4: New USB device found, idVendor=05e3, idProduct=0608
[ 3.010512] usb 1-1.3.4: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 3.010530] usb 1-1.3.4: Product: USB2.0 Hub
[ 3.012026] hub 1-1.3.4:1.0: USB hub found
[ 3.012527] hub 1-1.3.4:1.0: 4 ports detected
[ 3.051355] scsi 0:0:0:0: Direct-Access SanDisk Cruzer Edge 1.26 PQ: 0 ANSI: 5
[ 3.069359] sd 0:0:0:0: [sda] 15633408 512-byte logical blocks: (8.00 GB/7.45 GiB)
[ 3.079869] sd 0:0:0:0: [sda] Write Protect is off
[ 3.079911] sd 0:0:0:0: [sda] Mode Sense: 43 00 00 00
[ 3.080590] sd 0:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn’t support DPO or FUA
[ 3.107880] sda: sda1
[ 3.113183] sd 0:0:0:0: [sda] Attached SCSI removable disk
[ 3.130023] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[ 3.130129] VFS: Mounted root (ext4 filesystem) readonly on device 8:1.
[ 3.140829] devtmpfs: mounted
[ 3.142189] Freeing unused kernel memory: 332K (c093d000 - c0990000)
[ 3.288631] usb 1-1.3.4.1: new high-speed USB device number 9 using dwc_otg
[ 3.391951] usb 1-1.3.4.1: New USB device found, idVendor=0bda, idProduct=8172
[ 3.391989] usb 1-1.3.4.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 3.392008] usb 1-1.3.4.1: Product: RTL8191S WLAN Adapter
[ 3.392027] usb 1-1.3.4.1: Manufacturer: Manufacturer Realtek
[ 3.392043] usb 1-1.3.4.1: SerialNumber: 00e04c000001
[ 3.468690] usb 1-1.3.4.2: new low-speed USB device number 10 using dwc_otg
[ 3.677101] usb 1-1.3.4.2: New USB device found, idVendor=04d9, idProduct=1603
[ 3.677137] usb 1-1.3.4.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 3.677156] usb 1-1.3.4.2: Product: USB Keyboard
[ 3.677172] usb 1-1.3.4.2: Manufacturer:
[ 3.732777] input: USB Keyboard as /devices/platform/soc/20980000.usb/usb1/1-1/1-1.3/1-1.3.4/1-1.3.4.2/1-1.3.4.2:1.0/0003:04D9:1603.0001/input/input0
[ 3.789075] hid-generic 0003:04D9:1603.0001: input,hidraw0: USB HID v1.10 Keyboard [ USB Keyboard] on usb-20980000.usb-1.3.4.2/input0
[ 3.875613] input: USB Keyboard as /devices/platform/soc/20980000.usb/usb1/1-1/1-1.3/1-1.3.4/1-1.3.4.2/1-1.3.4.2:1.1/0003:04D9:1603.0002/input/input1
[ 3.929104] hid-generic 0003:04D9:1603.0002: input,hidraw1: USB HID v1.10 Device [ USB Keyboard] on usb-20980000.usb-1.3.4.2/input1
[ 4.008624] usb 1-1.3.4.3: new high-speed USB device number 11 using dwc_otg
[ 4.109965] usb 1-1.3.4.3: New USB device found, idVendor=1058, idProduct=1021
[ 4.110004] usb 1-1.3.4.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 4.110022] usb 1-1.3.4.3: Product: Ext HDD 1021
[ 4.110038] usb 1-1.3.4.3: Manufacturer: Western Digital
[ 4.110054] usb 1-1.3.4.3: SerialNumber: 574D43315434323832323835
[ 4.111471] usb-storage 1-1.3.4.3:1.0: USB Mass Storage device detected
[ 4.119123] scsi host1: usb-storage 1-1.3.4.3:1.0
[ 4.198644] usb 1-1.3.4.4: new high-speed USB device number 12 using dwc_otg
[ 4.299972] usb 1-1.3.4.4: New USB device found, idVendor=1058, idProduct=1021
[ 4.300009] usb 1-1.3.4.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 4.300031] usb 1-1.3.4.4: Product: Ext HDD 1021
[ 4.300047] usb 1-1.3.4.4: Manufacturer: Western Digital
[ 4.300064] usb 1-1.3.4.4: SerialNumber: 574D43315434313036383235
[ 4.301480] usb-storage 1-1.3.4.4:1.0: USB Mass Storage device detected
[ 4.309114] scsi host2: usb-storage 1-1.3.4.4:1.0
[ 4.874385] random: nonblocking pool is initialized
[ 5.121658] scsi 1:0:0:0: Direct-Access WD Ext HDD 1021 2021 PQ: 0 ANSI: 4
[ 5.124312] sd 1:0:0:0: [sdb] 732566016 4096-byte logical blocks: (2.93 TB/2.72 TiB)
[ 5.126586] sd 1:0:0:0: [sdb] Write Protect is off
[ 5.126638] sd 1:0:0:0: [sdb] Mode Sense: 17 00 10 08
[ 5.129006] sd 1:0:0:0: [sdb] No Caching mode page found
[ 5.129050] sd 1:0:0:0: [sdb] Assuming drive cache: write through
[ 5.131194] sd 1:0:0:0: [sdb] 732566016 4096-byte logical blocks: (2.93 TB/2.72 TiB)
[ 5.156334] sdb: sdb1
[ 5.159449] sd 1:0:0:0: [sdb] 732566016 4096-byte logical blocks: (2.93 TB/2.72 TiB)
[ 5.163238] sd 1:0:0:0: [sdb] Attached SCSI disk
[ 5.174061] NET: Registered protocol family 10
[ 5.311562] scsi 2:0:0:0: Direct-Access WD Ext HDD 1021 2021 PQ: 0 ANSI: 4
[ 5.313991] sd 2:0:0:0: [sdc] 732566016 4096-byte logical blocks: (2.93 TB/2.72 TiB)
[ 5.315999] sd 2:0:0:0: [sdc] Write Protect is off
[ 5.316050] sd 2:0:0:0: [sdc] Mode Sense: 17 00 10 08
[ 5.318130] sd 2:0:0:0: [sdc] No Caching mode page found
[ 5.318234] sd 2:0:0:0: [sdc] Assuming drive cache: write through
[ 5.320850] sd 2:0:0:0: [sdc] 732566016 4096-byte logical blocks: (2.93 TB/2.72 TiB)
[ 5.962895] systemd[1]: Cannot add dependency job for unit display-manager.service, ignoring: Unit display-manager.service failed to load: No such file or directory.
[ 5.963610] systemd[1]: Found ordering cycle on basic.target/start
[ 5.963680] systemd[1]: Found dependency on sysinit.target/start
[ 5.963744] systemd[1]: Found dependency on kbd.service/start
[ 5.963801] systemd[1]: Found dependency on remote-fs.target/start
[ 5.963851] systemd[1]: Found dependency on remote-fs-pre.target/start
[ 5.963899] systemd[1]: Found dependency on connman.service/start
[ 5.963945] systemd[1]: Found dependency on dbus.service/start
[ 5.963989] systemd[1]: Found dependency on basic.target/start
[ 5.964039] systemd[1]: Breaking ordering cycle by deleting job kbd.service/start
[ 5.964090] systemd[1]: Job kbd.service/start deleted to break ordering cycle starting with basic.target/start
[ 5.964894] systemd[1]: Found ordering cycle on basic.target/start
[ 5.964968] systemd[1]: Found dependency on sysinit.target/start
[ 5.965076] systemd[1]: Found dependency on rpcbind.service/start
[ 5.965141] systemd[1]: Found dependency on network-online.target/start
[ 5.965192] systemd[1]: Found dependency on network.target/start
[ 5.965237] systemd[1]: Found dependency on connman.service/start
[ 5.965286] systemd[1]: Found dependency on dbus.service/start
[ 5.965331] systemd[1]: Found dependency on basic.target/start
[ 5.965380] systemd[1]: Breaking ordering cycle by deleting job rpcbind.service/start
[ 5.965432] systemd[1]: Job rpcbind.service/start deleted to break ordering cycle starting with basic.target/start
[ 5.969958] sdc: sdc1
[ 5.972779] sd 2:0:0:0: [sdc] 732566016 4096-byte logical blocks: (2.93 TB/2.72 TiB)
[ 5.976775] sd 2:0:0:0: [sdc] Attached SCSI disk
[ 6.197482] fuse init (API version 7.23)
[ 6.608726] EXT4-fs (sda1): re-mounted. Opts: (null)
[ 7.949198] systemd-udevd[119]: starting version 215
[ 9.114191] usbcore: registered new interface driver uas
[ 9.172786] media: Linux media interface: v0.10
[ 9.264193] r8712u: module is from the staging directory, the quality is unknown, you have been warned.
[ 9.354056] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 9.381794] r8712u: register rtl8712_netdev_ops to netdev_ops
[ 9.381848] usb 1-1.3.4.1: r8712u: USB_SPEED_HIGH with 4 endpoints
[ 9.383425] sd 1:0:0:0: Attached scsi generic sg1 type 0
[ 9.383934] sd 2:0:0:0: Attached scsi generic sg2 type 0
[ 9.407766] Linux video capture interface: v2.00
[ 9.411148] usb 1-1.3.4.1: r8712u: Boot from EFUSE: Autoload OK
[ 9.537054] em28xx: New device TERRATEC Cinergy HTC Stick @ 480 Mbps (0ccd:00b2, interface 0, class 0)
[ 9.537092] em28xx: Audio interface 0 found (Vendor Class)
[ 9.537110] em28xx: Video interface 0 found: isoc
[ 9.537122] em28xx: DVB interface 0 found: isoc
[ 9.537377] em28xx: chip ID is em2884
[ 9.558448] Bluetooth: Core ver 2.20
[ 9.576135] NET: Registered protocol family 31
[ 9.576171] Bluetooth: HCI device and connection manager initialized
[ 9.576211] Bluetooth: HCI socket layer initialized
[ 9.576242] Bluetooth: L2CAP socket layer initialized
[ 9.576304] Bluetooth: SCO socket layer initialized
[ 9.607278] em2884 #0: EEPROM ID = 26 00 00 00, EEPROM hash = 0xfebadddc
[ 9.607310] em2884 #0: EEPROM info:
[ 9.607326] em2884 #0: microcode start address = 0x0004, boot configuration = 0x00
[ 9.622295] em2884 #0: I2S audio, 5 sample rates
[ 9.622335] em2884 #0: 500mA max power
[ 9.622354] em2884 #0: Table at offset 0x27, strings=0x249a, 0x1c6a, 0x1486
[ 9.622735] em2884 #0: Identified as Terratec Cinergy HTC Stick (card=82)
[ 9.622763] em2884 #0: analog set to isoc mode.
[ 9.622776] em2884 #0: dvb set to isoc mode.
[ 9.624254] usbcore: registered new interface driver em28xx
[ 9.691761] em2884 #0: Binding audio extension
[ 9.691793] em28xx-audio.c: Copyright © 2006 Markus Rechberger
[ 9.691805] em28xx-audio.c: Copyright © 2007-2014 Mauro Carvalho Chehab
[ 9.691983] em2884 #0: Endpoint 0x83 high-speed on intf 0 alt 7 interval = 8, size 196
[ 9.692008] em2884 #0: Number of URBs: 1, with 64 packets and 192 size
[ 9.695686] em2884 #0: Audio extension successfully initialized
[ 9.695720] em28xx: Registered (Em28xx Audio Extension) extension
[ 9.724226] usbcore: registered new interface driver btusb
[ 9.771212] em2884 #0: Binding DVB extension
[ 9.984225] snd-hifiberry-dac sound: pcm5102a-hifi <-> 20203000.i2s mapping ok
[ 10.372054] usb 1-1.3.3: Direct firmware load for dvb-usb-terratec-htc-stick-drxk.fw failed with error -2
[ 10.372103] drxk: Could not load firmware file dvb-usb-terratec-htc-stick-drxk.fw.
[ 10.372119] drxk: Copy dvb-usb-terratec-htc-stick-drxk.fw to your hotplug directory!
[ 10.395547] drxk: status = 0x639260d9
[ 10.395591] drxk: detected a drx-3926k, spin A3, xtal 20.250 MHz
[ 10.483758] drxk: DRXK driver version 0.9.4300
[ 10.525469] drxk: frontend initialized.
[ 10.568861] tda18271 4-0060: creating new instance
[ 10.571202] TDA18271HD/C2 detected @ 4-0060
[ 10.910348] DVB: registering new adapter (em2884 #0)
[ 10.910408] usb 1-1.3.3: DVB: registering adapter 0 frontend 0 (DRXK DVB-C DVB-T)…
[ 10.913301] em2884 #0: DVB extension successfully initialized
[ 10.913385] em28xx: Registered (Em28xx dvb Extension) extension
[ 10.992053] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 10.997287] em2884 #0: Registering input extension
[ 11.098655] Registered IR keymap rc-nec-terratec-cinergy-xs
[ 11.099548] input: em28xx IR (em2884 #0) as /devices/platform/soc/20980000.usb/usb1/1-1/1-1.3/1-1.3.3/rc/rc0/input2
[ 11.100460] rc0: em28xx IR (em2884 #0) as /devices/platform/soc/20980000.usb/usb1/1-1/1-1.3/1-1.3.3/rc/rc0
[ 11.100926] em2884 #0: Input extension successfully initalized
[ 11.100953] em28xx: Registered (Em28xx Input Extension) extension
[ 15.191134] smsc95xx 1-1.1:1.0 eth0: hardware isn’t capable of remote wakeup
[ 15.191880] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 16.440095] usb 1-1.3.4.1: r8712u: CustomerID = 0x000a
[ 16.440126] usb 1-1.3.4.1: r8712u: MAC Address from efuse = 24:05:0f:36:36:22
[ 16.440142] usb 1-1.3.4.1: r8712u: Loading firmware from “rtlwifi/rtl8712u.bin”
[ 16.440901] usbcore: registered new interface driver r8712u
[ 16.643407] systemd-journald[93]: Received request to flush runtime journal from PID 1
[ 16.756977] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 16.769530] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0x45E1
[ 16.856957] 8021q: 802.1Q VLAN Support v1.8
[ 19.730383] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 19.730408] Bluetooth: BNEP filters: protocol multicast
[ 19.730435] Bluetooth: BNEP socket layer initialized
[ 24.461829] EXT4-fs (sdc1): mounted filesystem with ordered data mode. Opts: (null)
[ 26.632010] EXT4-fs (sdb1): mounted filesystem with ordered data mode. Opts: (null)
[ 31.157996] Console: switching to colour dummy device 80x30
[ 325.020120] EXT4-fs (sdc1): error count since last fsck: 78
[ 325.020159] EXT4-fs (sdc1): initial error at time 1404078823: ext4_ext_check_inode:481: inode 38
[ 325.020186] EXT4-fs (sdc1): last error at time 1407886236: ext4_ext_check_inode:481: inode 38
[ 326.940082] EXT4-fs (sdb1): error count since last fsck: 3090
[ 326.940124] EXT4-fs (sdb1): initial error at time 1404078827: ext4_lookup:1436: inode 69730364
[ 326.940152] EXT4-fs (sdb1): last error at time 1424503720: ext4_mb_generate_buddy:757
[24661.859126] Transfer to device 6 endpoint 0x1 frame 1367 failed - FIQ reported NYET. Data may have been lost.
[27965.988044] Transfer to device 6 endpoint 0x1 frame 1623 failed - FIQ reported NYET. Data may have been lost.
[30608.523049] Transfer to device 6 endpoint 0x1 frame 1879 failed - FIQ reported NYET. Data may have been lost.
[40197.537785] Transfer to device 6 endpoint 0x1 frame 855 failed - FIQ reported NYET. Data may have been lost.
[53278.610963] Transfer to device 6 endpoint 0x1 frame 1623 failed - FIQ reported NYET. Data may have been lost.
