the PI2 positive 2017.08
osmc@osmc-salon:~$ grep VERSION_ID /etc/os-release
VERSION_ID=“2017.08-1”
Yes saw that from the logs. How about the Pi3?
no. that stays in 2017.07-1. I prefer no to touch the working one.
By the way, I updated the RPI2 from 2017.07-1 this morning, before it didn’t work either.
Well than your problem might be different.
You still could try the suggestions from @Tom_Doyle but maybe first check debug logs if you see anything
If its working on your pi3s you could try this:
copy /home/osmc/.smb/smb.conf on the pi3 and save it as:
/home/osmc/.kodi/smb/user.conf on one of the pi2s
Thanks Tom.
Hi Tom, I did the change to ~/.kodi/.smb/user.conf, I restarted the Pi but the shares are not working. Only if I allow “Guest Login” in the ASUS Router I’m able to see the NAS folders.
/home/osmc/.kodi/.smb
-rw-r–r-- 1 osmc osmc 217 Sep 1 08:49 user.conf
-rw-r–r-- 1 osmc osmc 154 Sep 1 08:54 smb.conf
[global]
lock directory = /home/osmc/.kodi/.smb/
client max protocol = SMB3
name resolve order = bcast host
include = /home/osmc/.kodi/.smb/user.conf
client use spnego = no
client ntlmv2 auth = no
Regards.
Please disable Guest login and provide more debug logs.
Thanks Tom.
Hi Tom, here is the log. https://paste.osmc.tv/ofewobahog
Regards
09:48:12.804 T:1679815664 ERROR: SMBDirectory->GetDirectory: Unable to open directory : 'smb://USERNAME:PASSWORD@192.168.1.1/Extras'
unix_err:'d' error : 'Permission denied'
09:48:12.804 T:1958191104 DEBUG: ------ Window Init (DialogSettings.xml) ------
09:48:12.805 T:1958191104 DEBUG: CSettingsManager: requested setting (user.name) was not found.
09:48:12.806 T:1958191104 DEBUG: CSettingsManager: requested setting (user.password) was not found.
09:48:12.806 T:1958191104 DEBUG: CSettingsManager: requested setting (user.rememberpassword) was not found.
try changing: client NTLMv2 auth = no to client NTLMv2 auth = yes
failing that check your username and password is correct.
Thanks Tom.
Hi, in ~/.kodi/.smb/user.conf??
Regards.
yes
no luck.
current log: https://paste.osmc.tv/votagameza
should I try downgrading¿?¿¿
Hi Tom, no luck. Here is the log: https://paste.osmc.tv/onetuseyez
This solution works for me, but it changes back when i reboot.
Old (working) file:
[global]
preferred master = no
local master = no
domain master = no
client lanman auth = yes
lanman auth = yes
socket options = TCP_NODELAY IPTOS_LOWDELAY SO_RCVBUF=65536 SO_SNDBUF=65536
lock directory = /home/osmc/.smb/
New (non-working) file:
[global]
My recommendation:
client lanman auth = yes lanman auth = yes client use spnego = no client ntlmv2 auth = no
Than reboot. This change should survive the reboot
@DavidUcles your log does not appear to show an attempt to access a samba share.
@alexisuceta & DavidUcles try fzinken suggested in post 60.
Thanks Tom.
Thank you very much fzinken and Tom, now it is working like before. I really appreciate all your help. One question, for a next update Do I need to verify the changes in the user.conf or is this a permanent change? Thanks.
Hi Tom, I followed the suggestion and now it is working like before. Thank you very much again for all your help, you gave us a great support all the time.
Regards.
Should be a permanent change. On the other hand you might can hope for a upgrade of your NAS for better security so that the changes are not needed anymore
Cool, thanks again.
