Can't browse music files web interface
Hello,
With the webinterface I can’t find any music files. At explorer > Video there is Auto mounted drive, but not at Music. Al my music is in FB71-32F6 flash drive. What can I do?
The auto mount system picks it up in Kodi under the video sources so if you want a folder to be navigable there without adding it to a library you would have to go in the regular interface on a TV and add it to music>files and then tell it to not add to library… or you could let it add to a library and then you can navigate through the music icon at the top of that page.
I added the path to music manually, it works now in main menu with a usb icon. Thanks!
