Maybe the PSU for your hard drive isn’t working properly and it is taking too much current from the RPi and causing you problems there?
I have done some tests…but the problem persist. I have reinstalled OSMC, change hdd, change wifi dongle and does not work.
It happens only with OSMC cause for example if I install LibreELEC it works fine…
Have you tried another PSU? I would do that first
Yes, I have changed the PSU too…
New log? Otherwise just stick with LE. You need to help us help help you
What PSU did you swap to?
I don’t really understand your question and it’s very difficult to refresh my memory when screenshots are on external links that don’t load
[quote=“sam_nazarko, post:46, topic:20062”]just stick with LE
[/quote]
Sounds like we have a solution
If we can’t get any further information and he has something that works, it’s the best one.
It’s reasonable to assume this isn’t a widespread issue.
Couldn’t agree more, with so little information to help the best thing for this user to do is use an alternate os that he can get working.
