OK, so on Kodi I tried.
Are you saying I should rather go w/ fstab on the 4k? On the router I had to check V2 otherwise it wouldn’t work
and: it’s only used locally
Like I said, unless you have you network open to the internet, I would not worry about the version of NFS you are using, so if it’s working for you know, leave it be.
fstab will give better performance, but with NFS mounts it’s not really that important.
