Hi, appreciate any help getting this dvb stick to work on my brand new Vero 2, which I got specifically to add to my Pi OSMC in order to add TV streaming and recording…
Appreciate that Sam, let me know if you need extra logs/command outputs.
To be honest, I’ll send you the stick if it helps as I’ve no other use for it. I did select it based on some research, but it would be much better to have an ‘official’ list of sticks on the site that are known to work on the Vero2/pi (I know it is is impossible for you to be more categorical than that given the open nature of the platform…).
Nice thought, but the stick doesn’t work on my Pi, but I think that is more to do with resources on the old Pi B that I have, hence my upgrade to vero.
It just means that the drivers are missing. I had assumed there was support for it on your Pi and you wanted it on the Vero 2. If you paste the output of lsusb (apt-get install usbutils first), I can see if it’s possible for me to add support.
Bus 001 Device 004: ID 2013:025f PCTV Systems
Bus 001 Device 003: ID 2252:1037
Bus 001 Device 002: ID 05e3:0608 Genesys Logic, Inc. USB-2.0 4-Port HUB
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Similar on my PI after moving the stick across:
Bus 001 Device 008: ID 1a40:0101 Terminus Technology Inc. 4-Port HUB
Bus 001 Device 007: ID 046d:c52f Logitech, Inc. Unifying Receiver
Bus 001 Device 012: ID 2013:025f PCTV Systems
Bus 001 Device 006: ID 05e3:0608 Genesys Logic, Inc. USB-2.0 4-Port HUB
Bus 001 Device 005: ID 05e3:0608 Genesys Logic, Inc. USB-2.0 4-Port HUB
Bus 001 Device 004: ID 18a5:0243 Verbatim, Ltd
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter
Bus 001 Device 002: ID 0424:9512 Standard Microsystems Corp. LAN9500 Ethernet 10/100 Adapter / SMSC9512/9514 Hub
But I lose power to the stick (blue light goes out) on the PI (despite powered hub) whereas it remains on with the vero…
