My 5TB USB HDD will not automount on my Vero for some reason.
It was previously /dev/sdd1 but know it’s not even listed when using df.
If I plug it into my Windows 10 laptop I can read and write to it with no issues.
I eject it and plug it into the Vero and it doesn’t see.
Tried different cables, different USB ports, cold booted teh Vero with it plugged in, nothing works.
It does show up in lsblk.
Any ideas?
osmc@osmc:~$ df
Filesystem 1K-blocks Used Available Use% Mounted on
devtmpfs 774688 0 774688 0% /dev
tmpfs 899236 8744 890492 1% /run
/dev/vero-nand/root 14499760 9533228 4206932 70% /
tmpfs 899236 0 899236 0% /dev/shm
tmpfs 5120 0 5120 0% /run/lock
tmpfs 899236 0 899236 0% /sys/fs/cgroup
/dev/sdb1 7811937256 94240 7811826632 1% /media/Seagate8TB-2
/dev/sda1 7811937256 7735346200 76574672 100% /media/Seagate8TB
/dev/sdc1 3904735508 2662298808 1242420316 69% /media/Seagate4TB
tmpfs 179844 0 179844 0% /run/user/1000
osmc@osmc:~$ lsblk
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT
sda 8:0 0 7.3T 0 disk
`-sda1 8:1 0 7.3T 0 part /media/Seagate8TB
sdb 8:16 0 7.3T 0 disk
`-sdb1 8:17 0 7.3T 0 part /media/Seagate8TB-2
sdc 8:32 0 3.7T 0 disk
`-sdc1 8:33 0 3.7T 0 part /media/Seagate4TB
sdd 8:48 0 4.6T 0 disk
`-sdd1 8:49 0 4.6T 0 part
mmcblk0 179:0 0 14.6G 0 disk
mmcblk0boot0 179:32 0 4M 0 disk
mmcblk0boot1 179:64 0 4M 0 disk
mmcblk0rpmb 179:96 0 4M 0 disk
Tried this with no luck:
osmc@osmc:~$ sudo mkdir /media/Seagate5TB
osmc@osmc:~$ sudo mount /dev/sdd1 /media/Seagate5TB
mount: wrong fs type, bad option, bad superblock on /dev/sdd1,
missing codepage or helper program, or other error
In some cases useful info is found in syslog - try
dmesg | tail or so.
It’s ext4.
Running fsck now, it found some issues it’s fixing.
I got a bunch of lines, more than I can count, that say something to this extent:
Group descriptor 37260 checksum is 0x0927, should be 0x4e64. FIXED.
Then it ended with this:
Pass 1: Checking inodes, blocks, and sizes
Pass 2: Checking directory structure
Pass 3: Checking directory connectivity
Pass 4: Checking reference counts
Pass 5: Checking group summary information
fsck: Warning… fsck.ext4 for device /dev/sdd1 exited with signal 9.
osmc@osmc:~$ sudo fsck /dev/sdd1
fsck from util-linux 2.29.2
e2fsck 1.43.4 (31-Jan-2017)
One or more block group descriptor checksums are invalid. Fix?
Try manually so that you see what is happening.
If mounting manually works suggest to backup the files and run smart test on the disk and then format it once more before recover the backup files.
dmesg | tail or so.
@fzinken
Backup completed.
SMART status good.
Any specific test you think should be ran to further check disk health or just go ahead and format the drive and transfer everything back?
SMART status good? Did you run a short/long smart test?
What are the error values? I think easiest is to use smartctl on the Vero and then paste-log the output.
osmc@osmc:~$ sudo smartctl -i /dev/sdc1
smartctl 6.6 2016-05-31 r4324 [aarch64-linux-3.14.29-152-osmc] (local build)
Copyright (C) 2002-16, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Vendor: Seagate
Product: BUP BK
Revision: 0304
Compliance: SPC-4
User Capacity: 5,000,981,077,504 bytes [5.00 TB]
Logical block size: 512 bytes
Physical block size: 4096 bytes
Logical Unit id: 0x5000000000000001
Serial number: NA9W6CCJ
Device type: disk
Local Time is: Wed Sep 25 20:38:11 2019 MST
SMART support is: Available - device has SMART capability.
SMART support is: Disabled
Temperature Warning: Disabled or Not Supported
osmc@osmc:~$ sudo smartctl -c /dev/sdc
/dev/sdc: Unknown USB bridge [0x0bc2:0xab28 (0x100)]
Please specify device type with the -d option.
Use smartctl -h to get a usage summary
