Hi guys
I am running Pi3 with OSMC media player (NOOBS_v1_9_2) and I can see the movie/music files on my external drive but when I play movies it fails to read or system just says working…
Everything work fine if I watch the same movies off my flash drive
This happens when the HD auto-mounts and also if I mount it manually - I have checked the permissions
My external is a 2Tb standard 2.5" SATA drive and uses NTFS
The Flash drive is EXFAT –
Do you think getting a USB hub to help power my external drive would make any difference?
To get a better understanding of the problem you are experiencing we need more information, including logs from you. Please see http://osmc.tv/wiki/general/how-to-submit-a-useful-support-request/ for advice on how to help us help you.
Sorry I am very new to this, I started debug and attempted to launch some movies that did not work
Copying URL not 100% sure how to upload logs
http://paste.osmc.io/atugibotih.vhdl
Sep 05 17:33:11 osmc kernel: Buffer I/O error on dev sda1, logical block 786584, async page read
Sep 05 17:33:11 osmc ntfs-3g[289]: ntfs_attr_pread_i: ntfs_pread failed: Input/output error
Sep 05 17:33:11 osmc ntfs-3g[289]: Failed to read of MFT, mft=611 count=1 br=-1: Input/output error
Sep 05 17:33:11 osmc kernel: usb 1-1.5: reset high-speed USB device number 5 using dwc_otg
Sep 05 17:33:12 osmc kernel: usb 1-1.5: reset high-speed USB device number 5 using dwc_otg
Sep 05 17:33:13 osmc kernel: usb 1-1.5: reset high-speed USB device number 5 using dwc_otg
Sep 05 17:33:13 osmc kernel: sd 0:0:0:0: [sda] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x07 driverbyte=0x00
Sep 05 17:33:13 osmc kernel: sd 0:0:0:0: [sda] tag#0 CDB: opcode=0x2a 2a 00 00 52 ae 20 00 00 10 00
Sep 05 17:33:13 osmc kernel: blk_update_request: I/O error, dev sda, sector 5418528
Sep 05 17:33:13 osmc kernel: Buffer I/O error on dev sda1, logical block 677060, lost async page write
Sep 05 17:33:13 osmc kernel: Buffer I/O error on dev sda1, logical block 677061, lost async page write
Sep 05 17:33:14 osmc kernel: usb 1-1.5: reset high-speed USB device number 5 using dwc_otg
Sep 05 17:33:14 osmc kernel: sd 0:0:0:0: [sda] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x07 driverbyte=0x00
Sep 05 17:33:14 osmc kernel: sd 0:0:0:0: [sda] tag#0 CDB: opcode=0x2a 2a 00 00 60 0a e0 00 00 18 00
Sep 05 17:33:14 osmc kernel: blk_update_request: I/O error, dev sda, sector 6294240
Sep 05 17:33:14 osmc kernel: Buffer I/O error on dev sda1, logical block 786524, lost async page write
Sep 05 17:33:14 osmc kernel: Buffer I/O error on dev sda1, logical block 786525, lost async page write
Sep 05 17:33:14 osmc kernel: Buffer I/O error on dev sda1, logical block 786526, lost async page write
Sep 05 17:33:15 osmc kernel: usb 1-1.5: reset high-speed USB device number 5 using dwc_otg
Sep 05 17:33:16 osmc kernel: usb 1-1.5: reset high-speed USB device number 5 using dwc_otg
Sep 05 17:33:16 osmc kernel: sd 0:0:0:0: [sda] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x07 driverbyte=0x00
Sep 05 17:33:16 osmc kernel: sd 0:0:0:0: [sda] tag#0 CDB: opcode=0x2a 2a 00 00 60 08 48 00 00 08 00
Sep 05 17:33:16 osmc kernel: blk_update_request: I/O error, dev sda, sector 6293576
Sep 05 17:33:16 osmc kernel: Buffer I/O error on dev sda1, logical block 786441, lost async page write
Sep 05 17:33:17 osmc kernel: usb 1-1.5: reset high-speed USB device number 5 using dwc_otg
Sep 05 17:33:17 osmc kernel: sd 0:0:0:0: [sda] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x07 driverbyte=0x00
Sep 05 17:33:17 osmc kernel: sd 0:0:0:0: [sda] tag#0 CDB: opcode=0x28 28 00 00 60 0c c8 00 00 08 00
Sep 05 17:33:17 osmc kernel: blk_update_request: I/O error, dev sda, sector 6294728
Sep 05 17:33:17 osmc kernel: Buffer I/O error on dev sda1, logical block 786585, async page read
Sep 05 17:33:17 osmc ntfs-3g[289]: ntfs_attr_pread_i: ntfs_pread failed: Input/output error
Sep 05 17:33:17 osmc ntfs-3g[289]: Failed to read of MFT, mft=612 count=1 br=-1: Input/output error
Sep 05 17:33:18 osmc kernel: usb 1-1.5: reset high-speed USB device number 5 using dwc_otg
Sep 05 17:33:18 osmc kernel: sd 0:0:0:0: [sda] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x07 driverbyte=0x00
Sep 05 17:33:18 osmc kernel: sd 0:0:0:0: [sda] tag#0 CDB: opcode=0x2a 2a 00 00 5e 36 18 00 00 10 00
Sep 05 17:33:18 osmc kernel: blk_update_request: I/O error, dev sda, sector 6174232
Sep 05 17:33:18 osmc kernel: Buffer I/O error on dev sda1, logical block 771523, lost async page write
Sep 05 17:33:18 osmc kernel: Buffer I/O error on dev sda1, logical block 771524, lost async page write
Sep 05 17:33:19 osmc kernel: usb 1-1.5: reset high-speed USB device number 5 using dwc_otg
Sep 05 17:33:20 osmc kernel: usb 1-1.5: reset high-speed USB device number 5 using dwc_otg
Sep 05 17:33:20 osmc kernel: sd 0:0:0:0: [sda] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x07 driverbyte=0x00
Sep 05 17:33:20 osmc kernel: sd 0:0:0:0: [sda] tag#0 CDB: opcode=0x2a 2a 00 00 c5 95 a8 00 00 10 00
Sep 05 17:33:20 osmc kernel: blk_update_request: I/O error, dev sda, sector 12948904
Sep 05 17:33:20 osmc kernel: Buffer I/O error on dev sda1, logical block 1618357, lost async page write
Sep 05 17:33:20 osmc kernel: Buffer I/O error on dev sda1, logical block 1618358, lost async page write
Sep 05 17:33:21 osmc kernel: usb 1-1.5: reset high-speed USB device number 5 using dwc_otg
Lots of this seems to indicate the drive is not being powered sufficiently. You should definitely try using a powered hub.
I used to have the same problem earlier so I brought a new USB powered hub which resolved the problem.
USB powered hub also allows you to seamlessly connect many USB devices depending on the number of ports available on the device.
Confirmed, USB hub sorted all my issues. Thank you
