Hello, I’m new to the forum so far enjoying OSMC coming from OpenElec.
One problem though. I have a repository zip on a USB stick but I can’t seem to get it working in OSMC. It was working fine in OpenElec just before I installed OSMC.
Just wondering if there is anything I can do that doesn’t result in needed OpenElec again.
How is your RPi powered? Are you using a good PSU?
I solved it. I installed OSMC onto a micro-sd card inserted into a USB adapter in windows but I chose USB via the OSMC installer instead of SD. I presume this screws up the installation somewhat. What would be the technicalities of this?, I would be interested if someone could enlighten me, here to learn.
Ok, that explains what I saw from your log file.
So actually you installed the boot files onto the SD Card and then have choosen to install OSMC onto the USB Stick. Which means the content of the USB Stick was overwritten by the Installer with OSMC OS files. Which means the USB stick was physically connected but you might just have not seen anymore the files you expected.
