Can't start dockers after update
Hello,
I did the latest update, but now my docker images don’t run.
osmc@vero:~/docker$ docker-compose up -d
docker: Error response from daemon: failed to create shim task: OCI runtime create failed: runc create failed: unable to start container process: error during container init: error setting cgroup config for procHooks process: bpf_prog_query(BPF_CGROUP_DEVICE) failed: invalid argument: unknown.
osmc@vero:~/docker$ docker run hello-world
ERRO[0000] error waiting for container: context canceled
I tried to reinstall docker using this script : til/yum-apt-repos-docker.md at master · ironicbadger/til · GitHub
I get the same error.
My Docker images are from linuxserver.io :
Docker Containers: 101 - LinuxServer.io
Any idea ?
Ah, it’s seem I’m not the only one :
Sorry I should have checked first.
