Hello,
A while ago, I stopped being able to open TV shows from the guide. I get the extremely frustrating “CHANNEL UNAVAILABLE” screen. I had other problems, as well, so last week I decided to build a new backend from scratch. Not the most fun I’ve ever had, but it is “done”. Now, on the new backend, I’m getting the same message.
NOTE: Recordings work, so if you just click on the program you want to watch and tell it to record it, then go into the recordings and play it while it is recording, it works (as a workaround). I don’t want to live like that though (and neither does my family)!
NOTE: the “Channel Unavailable” message pops up immediately - doesn’t seem take any time to try to tune in at all - instead seems to be tripping on something else.
So, I enabled more logging in the PVR settings, turned on logging and tried to tune into a channel. I got a bunch of stuff that looks pertinent, but I can’t decipher it and, as seems to be common for me, Google doesn’t seem to be much help.
I will note that I set this in my “advancedsettings.xml” a long time ago and I don’t know why - maybe it is related:
<pvr>
<minvideocachelevel>30</minvideocachelevel>
<minaudiocachelevel>30</minaudiocachelevel>
</pvr>
The errors I am getting look like this:
2020-05-19 22:55:12.897 T:1300742880 DEBUG: CMMALPool::Configure pool:0x6b0a37d0 960x540 (960x544) pix:-1 size:128 fmt:OPQV
2020-05-19 22:55:13.053 T:1428660960 DEBUG: Previous line repeats 2 times.
2020-05-19 22:55:13.053 T:1428660960 DEBUG: AddOnLog: MythTV PVR Client: SignalStatus
2020-05-19 22:55:13.053 T:1428660960 ERROR: SignalQuality: Add-on 'MythTV (hunchy):http://hunchy:6544' returned an error: rejected by the backend
2020-05-19 22:55:13.065 T:1499460320 ERROR: GetStreamTimes: Add-on 'MythTV (hunchy):http://hunchy:6544' returned an error: rejected by the backend
2020-05-19 22:55:13.085 T:1300742880 DEBUG: CMMALPool::Configure pool:0x6b0a37d0 960x540 (960x544) pix:-1 size:128 fmt:OPQV
2020-05-19 22:55:13.138 T:1472197344 DEBUG: Previous line repeats 2 times.
2020-05-19 22:55:13.138 T:1472197344 DEBUG: AddOnLog: MythTV PVR Client: RunHouseKeeping
2020-05-19 22:55:13.147 T:1300742880 DEBUG: CMMALPool::Configure pool:0x6b0a37d0 960x540 (960x544) pix:-1 size:128 fmt:OPQV
2020-05-19 22:55:13.270 T:1499460320 DEBUG: Previous line repeats 2 times.
2020-05-19 22:55:13.270 T:1499460320 ERROR: GetStreamTimes: Add-on 'MythTV (hunchy):http://hunchy:6544' returned an error: rejected by the backend
2020-05-19 22:55:13.350 T:1300742880 DEBUG: CMMALPool::Configure pool:0x6b0a37d0 960x540 (960x544) pix:-1 size:128 fmt:OPQV
2020-05-19 22:55:13.474 T:1499460320 DEBUG: Previous line repeats 5 times.
2020-05-19 22:55:13.474 T:1499460320 ERROR: GetStreamTimes: Add-on 'MythTV (hunchy):http://hunchy:6544' returned an error: rejected by the backend
2020-05-19 22:55:13.555 T:1428660960 DEBUG: AddOnLog: MythTV PVR Client: SignalStatus
2020-05-19 22:55:13.555 T:1428660960 ERROR: SignalQuality: Add-on 'MythTV (hunchy):http://hunchy:6544' returned an error: rejected by the backend
2020-05-19 22:55:13.583 T:1300742880 DEBUG: CMMALPool::Configure pool:0x6b0a37d0 960x540 (960x544) pix:-1 size:128 fmt:OPQV
2020-05-19 22:55:13.678 T:1499460320 DEBUG: Previous line repeats 4 times.
2020-05-19 22:55:13.679 T:1499460320 ERROR: GetStreamTimes: Add-on 'MythTV (hunchy):http://hunchy:6544' returned an error: rejected by the backend
2020-05-19 22:55:13.697 T:1300742880 DEBUG: CMMALPool::Configure pool:0x6b0a37d0 960x540 (960x544) pix:-1 size:128 fmt:OPQV
2020-05-19 22:55:13.883 T:1499460320 DEBUG: Previous line repeats 5 times.
2020-05-19 22:55:13.883 T:1499460320 ERROR: GetStreamTimes: Add-on 'MythTV (hunchy):http://hunchy:6544' returned an error: rejected by the backend
2020-05-19 22:55:13.947 T:1300742880 DEBUG: CMMALPool::Configure pool:0x6b0a37d0 960x540 (960x544) pix:-1 size:128 fmt:OPQV
2020-05-19 22:55:14.056 T:1428660960 DEBUG: AddOnLog: MythTV PVR Client: SignalStatus
2020-05-19 22:55:14.056 T:1428660960 ERROR: SignalQuality: Add-on 'MythTV (hunchy):http://hunchy:6544' returned an error: rejected by the backend
2020-05-19 22:55:14.067 T:1300742880 DEBUG: CMMALPool::Configure pool:0x6b0a37d0 960x540 (960x544) pix:-1 size:128 fmt:OPQV
2020-05-19 22:55:14.087 T:1499460320 DEBUG: Previous line repeats 2 times.
2020-05-19 22:55:14.087 T:1499460320 ERROR: GetStreamTimes: Add-on 'MythTV (hunchy):http://hunchy:6544' returned an error: rejected by the backend
2020-05-19 22:55:14.114 T:1300742880 DEBUG: CMMALPool::Configure pool:0x6b0a37d0 960x540 (960x544) pix:-1 size:128 fmt:OPQV
2020-05-19 22:55:14.143 T:1472197344 DEBUG: Previous line repeats 1 times.
2020-05-19 22:55:14.143 T:1472197344 DEBUG: AddOnLog: MythTV PVR Client: RunHouseKeeping
2020-05-19 22:55:14.181 T:1300742880 DEBUG: CMMALPool::Configure pool:0x6b0a37d0 960x540 (960x544) pix:-1 size:128 fmt:OPQV
2020-05-19 22:55:14.289 T:1499460320 ERROR: GetStreamTimes: Add-on 'MythTV (hunchy):http://hunchy:6544' returned an error: rejected by the backend
2020-05-19 22:55:14.317 T:1300742880 DEBUG: CMMALPool::Configure pool:0x6b0a37d0 960x540 (960x544) pix:-1 size:128 fmt:OPQV
2020-05-19 22:55:14.493 T:1499460320 DEBUG: Previous line repeats 5 times.
2020-05-19 22:55:14.493 T:1499460320 ERROR: GetStreamTimes: Add-on 'MythTV (hunchy):http://hunchy:6544' returned an error: rejected by the backend
2020-05-19 22:55:14.550 T:1300742880 DEBUG: CMMALPool::Configure pool:0x6b0a37d0 960x540 (960x544) pix:-1 size:128 fmt:OPQV
2020-05-19 22:55:14.557 T:1428660960 DEBUG: Previous line repeats 1 times.
2020-05-19 22:55:14.557 T:1428660960 DEBUG: AddOnLog: MythTV PVR Client: SignalStatus
2020-05-19 22:55:14.557 T:1428660960 ERROR: SignalQuality: Add-on 'MythTV (hunchy):http://hunchy:6544' returned an error: rejected by the backend
2020-05-19 22:55:14.560 T:1300742880 DEBUG: CMMALPool::Configure pool:0x6b0a37d0 960x540 (960x544) pix:-1 size:128 fmt:OPQV
2020-05-19 22:55:14.698 T:1499460320 DEBUG: Previous line repeats 3 times.
Any idea what the heck is going on?
Thanks!!
–mobrien118
