Cant't apply lirc.conf from My OSMC Remotes
Hi can’t apply any lirc.conf from the My OSMC remotes, there is no confirm window anymore and i don’t know what i’ve done.
Hi cybertronic,
What skin are you using?
Thanks Tom.
The default Kodi Krypton skin but it worked before with that skin. I think i destroied something in the lirc config.
EDIT: If i manualy copy the remote config to lirc.conf it works normal but i cant select it in MY OSMC
Logs may help diagnose the issue, but if you’ve think you have broken something it maybe better to back up your settings. Start with a new osmc image and restore.
Thanks Tom.
Is there a way to reinstall/reset the lirc service on osmc?
Ok i solved it after a apt-get update and after that apt-get -f install.
Glad to here its sorted.
Thanks Tom.
