Hi all, I need to push a maximum of 1080p to my display. On my 4k+, I just used the resolution setting but it doesn’t seem to be there in the V.
Has it moved? I can’t do it automatically as my HDFury sits between the Vero and the plasmazo it thinks it can take 4k. I know I can tinker with the Fury but they are a bit tricky and temperamental so I’d like to just tell the Vero to send nothing over 1080p
