Hi guys, I’m new to osmc, I installed it on my Raspberry pi 3 and installed simple IPTV addon.
I also added my playlist that is downloaded correctly.
But when I try to launch a stream in the logs I found:
20:43:04.042 T:1331500016 ERROR: CCurlFile::FillBuffer - Failed: HTTP returned error 401
20:43:04.042 T:1331500016 ERROR: CCurlFile::Open failed with code 401 for http://url/file.m3u8
using the same stream in VLC (with the m3u extension) I am able to see the streams.
Is that a common issue?
How can I get it solved?
Thank you!
