I have been using Raspbmc for quite a while on my RPi and I am very happy with it. Last week I got my new RPi 2 and directly tested OSMC alpha 4 on it. I let it index and scrape all my TV shows and it proved to be much faster! I can’t wait to test new alphas that will be even more adapted to it and will make use of the new CPU design.
However, just to mention a tiny thing that is nagging me since some time last year (so already on raspbmc): CEC glitches.
For every ~5th key I press on my remote the corresponding action is performed twice. Press down once will go down twice in a list and so on.
As far as searching on the net brought me I can say that it seems to be an issue of my TV set’s firmware (Panasonic), but for some reason it only occurred in more recent versions.
Of course I checked if something changed in OSMC but the issue is still there. For standard remotes there is a repeat filter already included, but for CEC protocol there is not. I am aware that are many many more pressing matters, but I just wanted to put this in, so it won’t be forgotten until there is time for these tiny things.
Same problem here on Panasonic Viera TV and OSMC on a Rbpi2
I Had the same problem on Raspbmc in the early days, then the problem went away, but the problem came again with or around the Kodi update.
I also have an issue on my Panasonic TV (42VT30). Instead of doing an action twice, it skips randomly so I have to press the button twice… really annoying!
I don’t have that issue with openelec or xbian.
Maybe it will get fixed in the next release (?) I read that Sam added a fix on libcec.
