Hello
TBH I am not 100% sure what the cause is. The symptoms are if I scroll quickly through the menus using the remote or for example I am trying to find a specific movie that involve multiple quick remote key presses my system will reboot. This behavior is erratic enough that I can’t replicate it on demand, so I can’t really test if the same occurs if I use a keyboard or yatse.
