I have a RBP-2 and I am using OSMC with a Samsung LCD TV without any problem.
Recently I wanted to use the same piece of hardware with an Philips LCD TV set. There I have picture but I can not control OSMC via CEC.
I discovered that I had the enable EasyLink at he Preference menu of the TV set. Now I can see from kodi.log that OSMC can communicate with the TV. But I did not find why I can not control OSMC with the remote control of the TV set ( Philips 47PFL9703.)
Here is the log from my RBP-2 when it is connected to the Philips TV set:
Any help or suggestion is appreciated to resolve this problem!
Thank you, i thought i was going insane. I have a similar Philips TV that used to work fine with my Pi1 and Raspbmc. But with my pi2 and osmc its not. I made a similar thread and it was suggested that i had a faulty pi2…so i just quit trying.
Try this. Open a putty session and type: tvservice -d edid.dat
Whats does it say ? If its not saying Nothing written, then attach the file here…The mods will need it.
And then also do: tvservice -s
A moderator must answer this. I cant help any further, but with the file you provided he’ll be able to help you out. Just wait for someone to see this thread and they’ll take over.
I have a Philips PFS8159 and CEC/Easylink works (I currently have different CEC issues though). Is your Pi plugged into the TV or the AVR? Does the RPi come up as “Kodi” in the “sources” screen of your TV or just as “HDMI1/2/3 etc”.?
