I have set cec logging, rebooted turned off the AV and TV on manually, turn them on again and, despit of EC/HDMI on the screen, the remote does not work - so used upload log in my osmc (I hope, there was no confirmation) - where/how you will identify them? Also tried to turn off the OSMC for 10 min. Only reboot syncs the remote with the OSMC and it starts to work.
… for upload + reboot I have used web interface
Sorry to here you are having issues, what osmc device are you having this issue on?
When you uploaded the logs, you should have been given a url; you need let us know what the url is.
Thanks Tom.
Hello
now it makes sense for me
I am running Pi2 and here is the URL with logs
https://paste.osmc.tv/utuwarukah
Marek
21:10:13.070 T:1805992944 ERROR: CecLogMessage - RegisterLogicalAddress - CEC is being used by another application. Run "tvservice --off" and try again.
21:10:13.070 T:1805992944 ERROR: CecLogMessage - Open - vc_cec could not be initialised
21:10:13.070 T:1805992944 ERROR: CecLogMessage - could not open a connection (try 2)
21:10:14.073 T:1805992944 ERROR: CecLogMessage - RegisterLogicalAddress - CEC is being used by another application. Run "tvservice --off" and try again.
21:10:14.081 T:1805992944 ERROR: CecLogMessage - Open - vc_cec could not be initialised
21:10:14.081 T:1805992944 ERROR: CecLogMessage - could not open a connection (try 3)
Well this is a weird one, it looks almost like as if something other than kodi is using cec?
I’m also seeing a repo listed here.
Can you please try a fresh install of osmc, with April’s update and see if the issue is still occurring.
Thanks Tom.
hmm this will take quite some time including all plugins and settings which I am not willing to spent now - it has clearly started after update, so… hope this will be fixed in the next one - as people asked for roll-back, maybe the ceclib will be fixed. Or is there a way how to copy settings? I guess this would not be the way how to test it right?
Thanks!
You can back and restore your settings using myosmc. I would start with a fresh install, check if cec is working or not. Then restore using myosmc.
Or you use win32diskimager, to create a full back up of your sd card. Then you can try a fresh install.
You may well be right that cec issue is only related to the update, but this could also be a configuration issue and the easiest way to confirm is with a fresh install.
Thanks Tom.
