(All working fine before the update, no manual changes made whatsoever)
My 4k+ is now randomly turning my tv/amp on, and my normal 4ks and the 4k+ are no longer turning stuff off when they go into standby. I’ve had to switch everything off at the plug to make sure it doesn’t turn my OLED on and leave it on alll day
same problem here
My chain looks like this: vero <->av receiver<->samsung tv
After around 2-3 hours the tv goes on and brings on the av receiver.
Even if i switch everything off in a different hdmi channel at av receiver the vero push himself in the front after 2-3 hours and turn everything on.
edit: it’s only 30 minutes and the standby timer is set to 30 minutes
I’ve had something similar but not turning everything on. The issue I have is when I switch all my stuff on, the Vero randomly steals the input. Connected like so: Vero 4k+ <-> Yamaha RX-V3070 <-> Samsung KS9000.
I had this problem before the most recent update, and so now I’ve just disabled CEC completely on the Vero. I would have preferred to keep it active to put the Vero into Suspend mode, but stealing the input was really annoying and was mucking up my Harmony activity status.
Similar issue here. Only started since the update. I don’t have an AV receiver, just got a Vero 4k+ connected directly to a Samsung UE40NU7120, and it’s been turning on while I’ve not been around.
I haven’t produced any logs yet. I’ll enable debug logging before I go to sleep tonight and hopefully will have a log file to upload in the morning.
Got exactly the same issue (direct connection to TV, no TV updates recently).
On top of that - quite often after sleep TV think there are no source connected.
Unplug/plug HDMI (or reboot) from Vero helps.
Edit:
when TV is turned ON, kodi.bin consume 80-170% CPU. HDMI cable replug not always fix the issue.
