Hi, I have Vero 4k+ and LG OLED55BX tv and want to use CEC (Simplink in LG terminology). Problem is, that the CEC (control Vero via tv remote) works for a couple of seconds then it does not for a while and then again it works. Since I have no problem with CEC on my previous tv (old plasma panasonic) I was thinking I did something to the HDMI cable when switching to the new tv, so I bought a new one, but that did not help. I have also tried numerous restarts and unpluggings of tv, vero 4k+ from HDMI and from the power, nothing helps.
Here is a log from echo scan | cec-client (from vero via ssh)
No device type given. Using 'recording device'
CEC Parser created - libCEC version 4.0.4
no serial port given. trying autodetect:
path: /dev/aocec
com port: AOCEC
opening a connection to the CEC adapter...
DEBUG: [ 156] Broadcast (F): osd name set to 'Broadcast'
NOTICE: [ 157] connection opened
DEBUG: [ 157] processor thread started
DEBUG: [ 157] << Broadcast (F) -> TV (0): POLL
TRAFFIC: [ 157] << f0
DEBUG: [ 219] >> POLL sent
DEBUG: [ 219] TV (0): device status changed into 'present'
DEBUG: [ 219] << requesting vendor ID of 'TV' (0)
TRAFFIC: [ 219] << f0:8c
TRAFFIC: [ 436] >> 0f:87:00:e0:91
DEBUG: [ 437] >> TV (0) -> Broadcast (F): device vendor id (87)
DEBUG: [ 437] TV (0): vendor = LG (00e091)
DEBUG: [ 437] expected response received (87: device vendor id)
DEBUG: [ 437] replacing the command handler for device 'TV' (0)
DEBUG: [ 437] TV (0): CEC version 1.3a
DEBUG: [ 437] TV (0): menu language set to 'eng'
NOTICE: [ 437] registering new CEC client - v4.0.4
DEBUG: [ 437] detecting logical address for type 'recording device'
DEBUG: [ 437] trying logical address 'Recorder 1'
DEBUG: [ 437] << Recorder 1 (1) -> Recorder 1 (1): POLL
TRAFFIC: [ 437] << 11
WARNING: [ 649] Write: write failed
TRAFFIC: [ 649] << 11
WARNING: [ 849] Write: write failed
DEBUG: [ 849] >> POLL not sent
DEBUG: [ 849] using logical address 'Recorder 1'
DEBUG: [ 849] Recorder 1 (1): device status changed into 'handled by libCEC'
DEBUG: [ 849] Recorder 1 (1): power status changed from 'unknown' to 'on'
DEBUG: [ 849] Recorder 1 (1): vendor = Pulse Eight (001582)
DEBUG: [ 849] Recorder 1 (1): CEC version 1.4
DEBUG: [ 849] AllocateLogicalAddresses - device '0', type 'recording device', LA '1'
DEBUG: [ 850] Recorder 1 (1): osd name set to 'CECTester'
DEBUG: [ 850] Recorder 1 (1): menu language set to 'eng'
DEBUG: [ 850] AutodetectPhysicalAddress - autodetected physical address '1000'
DEBUG: [ 850] Recorder 1 (1): physical address changed from ffff to 1000
DEBUG: [ 850] << Recorder 1 (1) -> broadcast (F): physical address 1000
TRAFFIC: [ 850] << 1f:84:10:00:01
NOTICE: [ 1009] CEC client registered: libCEC version = 4.0.4, client version = 4.0.4, firmware version = 5, logical address(es) = Recorder 1 (1) , physical address: 1.0.0.0, compiled on Thu Jul 2 21:53:58 UTC 2020 by root@compiler2 on Linux 4.19.0-9-amd64 (armv7l), features: P8_USB, DRM, P8_detect, AOCEC
DEBUG: [ 1009] Recorder 1 (1): vendor = LG (00e091)
DEBUG: [ 1009] replacing the command handler for device 'Recorder 1' (1)
DEBUG: [ 1009] Recorder 1 (1): CEC version 1.3a
DEBUG: [ 1009] << Recorder 1 (1) -> TV (0): OSD name 'CECTester'
TRAFFIC: [ 1009] << 10:47:43:45:43:54:65:73:74:65:72
DEBUG: [ 1339] << requesting power status of 'TV' (0)
TRAFFIC: [ 1339] << 10:8f
DEBUG: [ 2479] expected response not received (90: report power status)
TRAFFIC: [ 2479] << 10:8f
TRAFFIC: [ 2648] >> 01:90:00
DEBUG: [ 2648] TV (0): power status changed from 'unknown' to 'on'
DEBUG: [ 2648] >> TV (0) -> Recorder 1 (1): report power status (90)
waiting for input
requesting CEC bus information ...
DEBUG: [ 2648] expected response received (90: report power status)
DEBUG: [ 2648] << Recorder 1 (1) -> Recorder 2 (2): POLL
TRAFFIC: [ 2648] << 12
WARNING: [ 2859] Write: write failed
TRAFFIC: [ 2859] << 12
WARNING: [ 3179] Write: write failed
DEBUG: [ 3179] >> POLL not sent
DEBUG: [ 3179] Recorder 2 (2): device status changed into 'not present'
DEBUG: [ 3179] << Recorder 1 (1) -> Tuner 1 (3): POLL
TRAFFIC: [ 3179] << 13
WARNING: [ 3379] Write: write failed
TRAFFIC: [ 3379] << 13
WARNING: [ 3579] Write: write failed
DEBUG: [ 3579] >> POLL not sent
DEBUG: [ 3579] Tuner 1 (3): device status changed into 'not present'
DEBUG: [ 3579] << Recorder 1 (1) -> Playback 1 (4): POLL
TRAFFIC: [ 3579] << 14
WARNING: [ 3779] Write: write failed
TRAFFIC: [ 3779] << 14
WARNING: [ 3979] Write: write failed
DEBUG: [ 3979] >> POLL not sent
DEBUG: [ 3979] Playback 1 (4): device status changed into 'not present'
DEBUG: [ 3979] << Recorder 1 (1) -> Audio (5): POLL
TRAFFIC: [ 3979] << 15
WARNING: [ 4189] Write: write failed
TRAFFIC: [ 4189] << 15
WARNING: [ 4389] Write: write failed
DEBUG: [ 4389] >> POLL not sent
DEBUG: [ 4389] Audio (5): device status changed into 'not present'
DEBUG: [ 4389] << Recorder 1 (1) -> Tuner 2 (6): POLL
TRAFFIC: [ 4389] << 16
WARNING: [ 4589] Write: write failed
TRAFFIC: [ 4589] << 16
WARNING: [ 4789] Write: write failed
DEBUG: [ 4789] >> POLL not sent
DEBUG: [ 4789] Tuner 2 (6): device status changed into 'not present'
DEBUG: [ 4789] << Recorder 1 (1) -> Tuner 3 (7): POLL
TRAFFIC: [ 4789] << 17
DEBUG: [ 6829] >> POLL sent
DEBUG: [ 6829] Tuner 3 (7): device status changed into 'present'
DEBUG: [ 6829] << Recorder 1 (1) -> Playback 2 (8): POLL
TRAFFIC: [ 6829] << 18
TRAFFIC: [ 6829] >> 01:44:02
DEBUG: [ 6829] >> TV (0) -> Recorder 1 (1): user control pressed (44)
WARNING: [ 7029] Write: write failed
TRAFFIC: [ 7029] << 18
WARNING: [ 7229] Write: write failed
DEBUG: [ 7229] >> POLL not sent
DEBUG: [ 7229] Playback 2 (8): device status changed into 'not present'
DEBUG: [ 7229] << Recorder 1 (1) -> Recorder 3 (9): POLL
TRAFFIC: [ 7229] << 19
WARNING: [ 7949] Write: write failed
TRAFFIC: [ 7949] << 19
WARNING: [ 8149] Write: write failed
DEBUG: [ 8149] >> POLL not sent
DEBUG: [ 8149] Recorder 3 (9): device status changed into 'not present'
DEBUG: [ 8149] << Recorder 1 (1) -> Tuner 4 (A): POLL
TRAFFIC: [ 8149] << 1a
DEBUG: [ 10189] >> POLL sent
DEBUG: [ 10189] Tuner 4 (A): device status changed into 'present'
DEBUG: [ 10189] SetCurrentButton down (2) D:0ms cur:2
DEBUG: [ 10189] key pressed: down (2) current(ff) duration(0)
DEBUG: [ 10189] Changed key down (2) D:0ms cur:ff
DEBUG: [ 10189] << Recorder 1 (1) -> Playback 3 (B): POLL
TRAFFIC: [ 10189] << 1b
DEBUG: [ 10189] key pressed: down (2, 0)
DEBUG: [ 10189] making Recorder 1 (1) the active source
WARNING: [ 10649] Write: write failed
NOTICE: [ 10649] >> source activated: Recorder 1 (1)
DEBUG: [ 10649] CheckKeypressTimeout T:129.870
DEBUG: [ 10649] Key down: idle (duration:0) (2) timeout:-170926648ms (rel:40,rep:0,prs:40,rel:0)
TRAFFIC: [ 10649] >> 01:44:02
DEBUG: [ 10649] SetCurrentButton down (2) D:0ms cur:2
DEBUG: [ 10649] key pressed: down (2) current(2) duration(0)
DEBUG: [ 10649] key pressed: down (2, 0)
DEBUG: [ 10649] Key down: idle (duration:0) (2) timeout:-170926648ms (rel:500,rep:0,prs:500,rel:0)
TRAFFIC: [ 10649] >> 01:45
DEBUG: [ 10649] key released: down (2) D:460ms
DEBUG: [ 10649] << POLL: TV (0) -> Recorder 1 (1)
TRAFFIC: [ 10649] >> 01:89:0b
DEBUG: [ 10649] Recorder 1 (1): power status changed from 'on' to 'in transition from standby to on'
DEBUG: [ 10649] << Recorder 1 (1) -> TV (0): in transition from standby to on
TRAFFIC: [ 10649] << 10:90:02
DEBUG: [ 10649] >> TV (0) -> Recorder 1 (1): user control pressed (44)
DEBUG: [ 10649] >> TV (0) -> Recorder 1 (1): user control release (45)
DEBUG: [ 10649] >> TV (0) -> Recorder 1 (1): vendor command (89)
DEBUG: [ 10839] Recorder 1 (1): power status changed from 'in transition from standby to on' to 'on'
TRAFFIC: [ 10839] << 1b
WARNING: [ 11159] Write: write failed
DEBUG: [ 11159] >> POLL not sent
DEBUG: [ 11159] Playback 3 (B): device status changed into 'not present'
DEBUG: [ 11159] << Recorder 1 (1) -> Reserved 1 (C): POLL
TRAFFIC: [ 11159] << 1c
WARNING: [ 11359] Write: write failed
TRAFFIC: [ 11359] << 1c
WARNING: [ 11559] Write: write failed
DEBUG: [ 11559] >> POLL not sent
DEBUG: [ 11559] Reserved 1 (C): device status changed into 'not present'
DEBUG: [ 11559] << Recorder 1 (1) -> Reserved 2 (D): POLL
TRAFFIC: [ 11559] << 1d
WARNING: [ 11759] Write: write failed
TRAFFIC: [ 11759] << 1d
WARNING: [ 11959] Write: write failed
DEBUG: [ 11959] >> POLL not sent
DEBUG: [ 11959] Reserved 2 (D): device status changed into 'not present'
DEBUG: [ 11959] << Recorder 1 (1) -> Free use (E): POLL
TRAFFIC: [ 11959] << 1e
WARNING: [ 12169] Write: write failed
TRAFFIC: [ 12169] << 1e
WARNING: [ 12369] Write: write failed
DEBUG: [ 12369] >> POLL not sent
DEBUG: [ 12369] Free use (E): device status changed into 'not present'
DEBUG: [ 12369] << requesting vendor ID of 'Tuner 3' (7)
TRAFFIC: [ 12369] << 17:8c
WARNING: [ 12549] Write: write failed
TRAFFIC: [ 12549] << 17:8c
WARNING: [ 12729] Write: write failed
DEBUG: [ 12729] << requesting vendor ID of 'Tuner 3' (7)
TRAFFIC: [ 12729] << 17:8c
WARNING: [ 12909] Write: write failed
TRAFFIC: [ 12909] << 17:8c
WARNING: [ 13089] Write: write failed
DEBUG: [ 13089] << requesting physical address of 'Tuner 3' (7)
TRAFFIC: [ 13089] << 17:83
WARNING: [ 13269] Write: write failed
TRAFFIC: [ 13269] << 17:83
WARNING: [ 13449] Write: write failed
ERROR: [ 13449] failed to request the physical address
DEBUG: [ 13450] << requesting CEC version of 'Tuner 3' (7)
TRAFFIC: [ 13450] << 17:9f
WARNING: [ 13629] Write: write failed
TRAFFIC: [ 13629] << 17:9f
WARNING: [ 13809] Write: write failed
DEBUG: [ 13809] << requesting power status of 'Tuner 3' (7)
TRAFFIC: [ 13809] << 17:8f
WARNING: [ 13989] Write: write failed
TRAFFIC: [ 13989] << 17:8f
WARNING: [ 14169] Write: write failed
DEBUG: [ 14169] << requesting OSD name of 'Tuner 3' (7)
TRAFFIC: [ 14169] << 17:46
WARNING: [ 14349] Write: write failed
TRAFFIC: [ 14349] << 17:46
WARNING: [ 14529] Write: write failed
DEBUG: [ 14529] << requesting menu language of 'Tuner 3' (7)
TRAFFIC: [ 14529] << 17:91
WARNING: [ 14709] Write: write failed
TRAFFIC: [ 14709] << 17:91
WARNING: [ 14889] Write: write failed
DEBUG: [ 14889] << requesting vendor ID of 'Tuner 4' (A)
TRAFFIC: [ 14889] << 1a:8c
WARNING: [ 15069] Write: write failed
TRAFFIC: [ 15069] << 1a:8c
WARNING: [ 15249] Write: write failed
DEBUG: [ 15249] << requesting vendor ID of 'Tuner 4' (A)
TRAFFIC: [ 15249] << 1a:8c
WARNING: [ 15429] Write: write failed
TRAFFIC: [ 15429] << 1a:8c
WARNING: [ 15609] Write: write failed
DEBUG: [ 15609] << requesting physical address of 'Tuner 4' (A)
TRAFFIC: [ 15609] << 1a:83
WARNING: [ 15789] Write: write failed
TRAFFIC: [ 15789] << 1a:83
WARNING: [ 15969] Write: write failed
ERROR: [ 15969] failed to request the physical address
DEBUG: [ 15969] << requesting CEC version of 'Tuner 4' (A)
TRAFFIC: [ 15969] << 1a:9f
WARNING: [ 16149] Write: write failed
TRAFFIC: [ 16149] << 1a:9f
WARNING: [ 16329] Write: write failed
DEBUG: [ 16329] << requesting power status of 'Tuner 4' (A)
TRAFFIC: [ 16329] << 1a:8f
WARNING: [ 16509] Write: write failed
TRAFFIC: [ 16509] << 1a:8f
WARNING: [ 16689] Write: write failed
DEBUG: [ 16689] << requesting OSD name of 'Tuner 4' (A)
TRAFFIC: [ 16689] << 1a:46
WARNING: [ 16869] Write: write failed
TRAFFIC: [ 16869] << 1a:46
WARNING: [ 17049] Write: write failed
DEBUG: [ 17049] << requesting menu language of 'Tuner 4' (A)
TRAFFIC: [ 17049] << 1a:91
WARNING: [ 17230] Write: write failed
TRAFFIC: [ 17230] << 1a:91
WARNING: [ 17409] Write: write failed
CEC bus information
device #0: TV
address: 0.0.0.0
active source: no
vendor: LG
osd string: TV
CEC version: 1.3a
power status: on
language: eng
device #1: Recorder 1
address: 1.0.0.0
active source: yes
vendor: LG
osd string: CECTester
CEC version: 1.3a
power status: on
language: eng
device #7: Tuner 3
address: f.f.f.f
active source: no
vendor: Unknown
osd string: Tuner 3
CEC version: unknown
power status: unknown
language: ???
device #A: Tuner 4
address: f.f.f.f
active source: no
vendor: Unknown
osd string: Tuner 4
language: ???
currently active source: Recorder 1 (1)
TRAFFIC: [ 23229] >> 01
DEBUG: [ 23229] << POLL: TV (0) -> Recorder 1 (1)
TRAFFIC: [ 28219] >> 01:44:02
DEBUG: [ 28219] SetCurrentButton down (2) D:0ms cur:2
DEBUG: [ 28219] key pressed: down (2) current(ff) duration(0)
DEBUG: [ 28219] Changed key down (2) D:0ms cur:ff
DEBUG: [ 28219] key pressed: down (2, 0)
DEBUG: [ 28219] CheckKeypressTimeout T:147.440
DEBUG: [ 28219] Key down: idle (duration:0) (2) timeout:-170926648ms (rel:500,rep:0,prs:500,rel:0)
DEBUG: [ 28219] >> TV (0) -> Recorder 1 (1): user control pressed (44)
TRAFFIC: [ 28481] >> 01:44:02
DEBUG: [ 28481] SetCurrentButton down (2) D:0ms cur:2
DEBUG: [ 28481] key pressed: down (2) current(2) duration(0)
DEBUG: [ 28481] key pressed: down (2, 0)
DEBUG: [ 28481] CheckKeypressTimeout T:147.702
DEBUG: [ 28481] Key down: idle (duration:0) (2) timeout:-170926648ms (rel:500,rep:0,prs:500,rel:0)
DEBUG: [ 28482] >> TV (0) -> Recorder 1 (1): user control pressed (44)
TRAFFIC: [ 28870] >> 01:44:02
DEBUG: [ 28870] SetCurrentButton down (2) D:0ms cur:2
DEBUG: [ 28870] key pressed: down (2) current(2) duration(0)
DEBUG: [ 28870] key pressed: down (2, 0)
DEBUG: [ 28870] CheckKeypressTimeout T:148.091
DEBUG: [ 28870] Key down: idle (duration:0) (2) timeout:-170926648ms (rel:500,rep:0,prs:500,rel:0)
DEBUG: [ 28870] >> TV (0) -> Recorder 1 (1): user control pressed (44)
TRAFFIC: [ 29269] >> 01:44:02
DEBUG: [ 29269] SetCurrentButton down (2) D:0ms cur:2
DEBUG: [ 29269] key pressed: down (2) current(2) duration(0)
DEBUG: [ 29269] key pressed: down (2, 0)
DEBUG: [ 29269] CheckKeypressTimeout T:148.490
DEBUG: [ 29269] Key down: idle (duration:0) (2) timeout:-170926648ms (rel:500,rep:0,prs:500,rel:0)
DEBUG: [ 29269] >> TV (0) -> Recorder 1 (1): user control pressed (44)
TRAFFIC: [ 29759] >> 01:45
DEBUG: [ 29759] key released: down (2) D:1540ms
DEBUG: [ 29759] >> TV (0) -> Recorder 1 (1): user control release (45)
TRAFFIC: [ 32638] >> 01:45
DEBUG: [ 32639] >> TV (0) -> Recorder 1 (1): user control release (45)
TRAFFIC: [ 37230] >> 01
DEBUG: [ 37230] << POLL: TV (0) -> Recorder 1 (1)
Please help
