My Samsung TV’s remote is no longer able to control the Vero 4K.
It has done previously, with no particular config by myself. I am unsure if and what updates have been applied. I have noted recently that even when it was working, it would take 20secs before the Vero would execute the commands.
@Tom_Doyle tried power cycling, no change in behaviour.
In the TV’s Anynet+ settings, I can search for devices, where it finds the Kodi device as well as my AVR SR578 says it has “Connection settings complete”. When I then choose the Kodi device, the Anynet+ overlay is on screen and finishes with “device is not connected” message.
@Numiah I tried a different hdmi cable, same result.
My AVR isn’t 4K capable. This is why the TV is directly connected to the Vero. AVR is only being used for its audio / speaker setup (in time to be retired for a Soundbar - another story)
If you disconnect (this is just for testing) the onkyo and any another hdmi equipment (if there is any), Are you able to choose the kodi and not get the error message?
Ahhh, that seems to have done it! Maybe that is the proper process to reset cec fully, at least on this Samsung model.
Not thoroughly tested everything, just enjoying a moment of success…
The AVR does support CEC, i thought they simply call it ARC (auto return channel) on receivers? But I am able to control volume and it turns on/off with the tv. All I use it for… waste, huh?
